Dear All,
I am trying to use the PORTA.4 of PIC16F628A as a digital output pin. Seems that the pin (A4) does not work as digital output. It is always 0 and inactive. However, POERTA3 works as digital output.
I have short of pins. So I need to configure PORTA4 into digital output.
Can one please shed light on this issue? Thanks. BTW, I connected a pull up resistor from 1k to 10k, but no luck yet.
You may please look at the Proteus design attached bellow.
