Author Topic: Jtag with a lattice LCMX0256C Rigol 1052e  (Read 8204 times)
Offline GGMMTopic starter
« on: October 20, 2023, 02:23:45 pm »
Hello,
I try to repair an oscilloscope
see here: https://www.eevblog.com/forum/repair/startup-rigol-1052e/msg5068690/#msg5068690
I tried with TopJtag to see the chain , but without success.
By cons when I connect only a component I see the Blackfin, but never the lattice. (Error no Jtag chain)
see here some exemple that works!!
https://www.eevblog.com/forum/testgear/backup-firmware-dg1022/
With them it works and they see  the 2 components.
I read this documentation (see  datasheet), do you think that sleep is activated and prevents the Jtag channel from working?  See p 2-21
It works correctly on other posts (See post before) with Rigol 1052E
Strange???
an idea?
cdt
Re: Jtag with a lattice LCMX0256C Rigol 1052e
« Reply #1 on: October 20, 2023, 02:26:24 pm »
.....Or Usb blaster not compatible with lattice????
Something to modify on connexion?? I have tested with  pullup resistor, it's the same
cdt
Online darkspr1te
  • Country: zm
« Reply #2 on: October 20, 2023, 02:47:31 pm »
If you have a arduino compatible device laying around you could try the jatgulator /jtag finder code and it will confirm the pinouts are correct, it also test for pullup /down configs too. I have used it to confirm lots of jtag interfaces,it will also test for jrst which some device need before you scanchain
darkspr1te
« Reply #3 on: October 20, 2023, 03:08:57 pm »
Hello Darkspr1te,
I looked at the motherboard. There is in pin 48 a 4.7k pullup resistor connected to the 3.3v.
So we are in compliance with the documentation. Signal sleep high = Jtag chain activated.
it's a good thing.
i have not a Jtagtor /find.
At this time the question is: a CLONE  Usb Blaster (Cheap China product) can work with a lattice  y/n?
Do we need a special jtag programmer for this Lattice component  as product Jtag SPI Programmer for LATTICE FPGA.
? I don’t know.
if somebody can confirm it's work whith an Usb Blaster
cdt
Online ataradov
    • Personal site
« Reply #4 on: October 20, 2023, 03:41:50 pm »
If you see at at least one device in the chain, your tools work. It is impossible to work with just one device in the JTAG chain and completely ignore the rest.
I would double check that Lattice device is actually in the chain, there may have been a board revision.
Wait, the other post you linked seems to have Altera FPGA in the chain. I'm confused.
« Last Edit: October 20, 2023, 03:46:21 pm by ataradov »
Alex
« Reply #5 on: October 20, 2023, 04:13:46 pm »
Ataradov,
There are actually in my chain 2 components as precised altera and blackfin
When both components are wired, the chain is not detected.
When I test one component at a time, I detect blackfin, but not alter it. (Of course the wiring is modified to test one / by one)
So, as the altera is never  seen, necessarily the blackfin is not also seen because they are chained at this time of the test.
Something "blocks" the altera.
I think you understand me.
Maybe there’s a connection problem on the altera?
see example:
https://www.eevblog.com/forum/fpga/first-fpga-pcb-jtag-unable-to-scan-device-chain/
i will inspect the mother board
cdt
Online ataradov
    • Personal site
« Reply #6 on: October 20, 2023, 04:43:42 pm »
There is a simple test for JTAG chains. Make sure that the scope is power cycled, then connect logic analyzer to the TDO of the last device in the chain and apply some clock to the TCK (from a signal generator or something like that). By default all devices will have their IDCODE register selected in the chain. Capture the first 64 bits and see if they correspond to the expected devices in the chain. This is a simple method that eliminates all the tools from the suspicion.
I would also check if Altera has some soft of code protection or JTAG disable function and if that may be set.
Alex
« Reply #7 on: October 20, 2023, 05:47:55 pm »
Ataradov,
I took apart the motherboard and looked at the connexions.
If I test the Jtad connexions  on the blackfin with an Ohmeter , the values are a few kiloOhms.
Where it becomes very strange is that on the Altera the values are either an open circuit, or 0.7MégaOhm according to the direction of the ohmeter.
Except the TCK at a few kiloOhms.
And this is not finished, if I press a little on the card, it goes from 0.7 MégaOhm to...11KiloOhm.  Ha!!!
So, there is something strange on this board.
Tomorrow when I see more clearly, I’m going to blow a hot air on the altera to see.
There must be some kind of dry weld somewhere.  Where??? I took apart the motherboard and looked at the connections.
If I test the Jtad connections on the blackfin with an Ohmetre, the values are a few kiloOhms.
Where it becomes very strange is that on the altera the values are either an open circuit, or 0.7MégaOhm according to the direction of the ohmeter.
Except the TCK at a few kiloohms.
So, there is something on weld on the board.
There must be some kind of dry weld somewhere.  I hope it’s not between the layers...LOL
to be continued.....
cdt
Offline SiliconWizard
« Reply #8 on: October 20, 2023, 11:27:13 pm »
Still not sure why you talked about a Lattice part that turned out to be Altera? Confusing.
« Reply #9 on: October 21, 2023, 09:53:14 am »
hello,
It’s not always easy to speak French to English. I use a translator.
I repeat the following post to understood.   https://www.eevblog.com/forum/testgear/backup-firmware-dg1022/
Look at the hand-made diagram, we see the Altera and not the lattice.
Yeah, it’s a little confusing talking about Lattice and Altera.
If we follow all the posts on this subject, we always talk about chaining JTAG  the lattice and the blackfin.
The goal is to reprogram a firmware, it’s complex.
This firmware can be installed in part in the S29GL032, and part in the lattice. I understood it like that with all posts on this subject.
 You have to read the posts about it, there are hundreds of pages.
This is a subject that dates back 10 years, we must get back in.
For now, the main point is to operate the Lattice alone in JTAG.  It's must work, but not on my board.
And there, no result for the moment.
Perhaps someone could measure the impedance on the Lattice’s JTAG port. I find strange results (Open, or 0.7Mohm), but TCK only some KOhm.
See the picture of connxion
So I’m digging this trail.
cdt
« Reply #10 on: October 21, 2023, 09:54:52 am »
the picture
Online ataradov
    • Personal site
« Reply #11 on: October 21, 2023, 02:42:36 pm »
Resistance from what to what you are measuring. You are doing some strange things.
If devices are in the chain, then TMS and TCK must be connected together. And TDO if one must be connected to the TDI of another. Are they connected this way?
Also, what is the deal with Lattice vs Altera? Is this a different board revision or what?
Alex
« Reply #12 on: October 21, 2023, 04:27:05 pm »
Ataradov,
I think it is difficult to be understood. lol
I break down the steps:
1st) when I connect the Jtag chain for the 2 components (Lattice and blackfin) and this in the rules of art, the chain is not detected. (Yes there is the TDO/TDI link between the 2 components)
2eme) When I connect ONLY the blackfin, IT IS RECOGNIZED.  (Only wires in this case on connector blacfin   + 3.3v)
3eme) When I connect ONLY the lattice, it is not recognized, (Only wires in this case on connector Lattice, 3.3v included)
 so this explains that point 1 does not work.
The question is always the same, Why is the Lattice not seen in jtag chain  with the USB Blaster and TOPJtag software?
In the posts I put the link, it works but Wiggler connection.
I put in red, the USB blaster connexion for the complete chain  (See picture)
I opened my USB Blaster, there is only one active component a CH552 ang regulator
it is noted on the serigraphy.
1 TCK 2 GND
3 TDO 4 UL
5TMS 6NCE
7 ASDO 8NCS8
9 TDI 10 GND
so only the same question, What is missing for the lattice to be seen with the USB Blaster?
cdt
« Reply #13 on: October 21, 2023, 04:36:22 pm »
I wonder if it does not need a particular driver for the usb blaster to recognize the lattice in the device manager?
Frankly I’m stuck
exemple:
https://www.latticesemi.com/support/answerdatabase/2/0/8/2081
some idea?
cdt
Online ataradov
    • Personal site
« Reply #14 on: October 21, 2023, 04:40:35 pm »
What exact lattice chip is this?
Alex
« Reply #15 on: October 21, 2023, 05:45:29 pm »
Ataradov,
it's on tittle of the post
Lattice LCMXO256C
cdt
Online ataradov
    • Personal site
« Reply #16 on: October 21, 2023, 06:07:36 pm »
Ok, this device has code protection, but it looks like it does not entirely disable the JTAG port, so I would expect identification to work.
I would do my experiment with clocking the Lattice JTAG port directly and observing its TDO output after the power cycle. If it does not shift out the IDCODE, then it is either dead or something else is wrong.
Alex
« Reply #17 on: October 21, 2023, 07:45:32 pm »
Ataradov,
I haven’t checked the Jtag signals with my other oscilloscope yet.
I came to almost the same conclusion that the circuit is down, but the Rigol bootes well and freezes after 6seconds.
The design is quite complex and as said before the firmware seems scattered on several circuits. It is interesting to look for the breakdown, but we are exhausted a little by force.
Meanwhile I looked for another driver and I found one. The problem is that it made me a blue screen of death.
So I went back to the one in quartus directly on the USB Blaster folder. (As at first installation, it's like a come back)  --> Now no bleu screen!
I have also installed the quartus version. it's the 13.1, not sure it is the last but I could do a test with, knowing that I do not know at all this software, so to discover.
I’m not sure this is the latest version.
INTEL also specifies to use this driver in the USB Blaster folder and not to choose the one in X32 or X64 folder.(It's that i have do to reinstall it)
Now the Usb Blaster  is a revision C model based on a CH552 I think, i don't know is this driver is completly compatible with it.
I found this artical, to be read:
https://en.kohacraft.com/archives/install-chinese-usb-blaster-drivers-to-windows-10.html
Well, this is the night here and as said, it carries advice
A+  for futures adventures! LOL
« Reply #18 on: October 21, 2023, 07:53:18 pm »
For your information in device manager:
Le périphérique USB\VID_09FB&PID_6001\FFFFFFFF a été démarré.
Nom du pilote : oem32.inf
GUID de classe : {36fc9e60-c465-11cf-8056-444553540000}
Service : AlteraUSBBlaster
Filtres inférieurs :
Filtres supérieurs :
good night
Online ataradov
    • Personal site
« Reply #19 on: October 21, 2023, 07:54:48 pm »
If that JTAG adapter can see one device, it is fine, there is no need to mess with it. It is just a dummy translator from USB to JTAG, all the scan logic is implemented in the software.
Alex
« Reply #20 on: October 22, 2023, 04:37:49 pm »
Ataradov,
Here is a video I found. (In russian)
This looks except that it is a Siglent.
Strangely it must chain 2 connections Jtag, but one is different (A right connector not soldered) and the other with 6 pins (left) does not seem used. The problem we see no wiring on the video and it seems in contradiction with everything I could read on the posts!
Note that its activity light is always on.
I’m even more confused
To dig.
cdt
Online ataradov
    • Personal site
« Reply #21 on: October 22, 2023, 04:44:55 pm »
I don't know why he did need to get both devices at the same time. It is possible that MAX V CPLD is somehow also involved in the connection to the target flash, so he needed to control both devices at the same time.
But again, we are looking at wildly different designs with move MAX V entering the picture.
Stop doing random stuff and start doing things that are known to work.
Alex
« Reply #22 on: October 23, 2023, 03:00:43 pm »
Hello Ataradov,
Yeah, it’s hard to figure out what’s going on. I am not a specialist engineer of FGPA or other and indeed I am trying to find what is wrong. It’s a retired hobby
On eevblog, I found a post where you intervened.
https://www.eevblog.com/forum/beginners/custom-fpga-dev-board-not-working/
help on:
https://www2.lauterbach.com/pdf/training_jtag.pdf
My idea is to know if it is possible to record what happens on the differents signals Tdi, tdo, etc to see.
I know it works with one component, not the other.
We are talking about a trace32 program.
Can be used with a USB blaster without add some extended card (?) and where to download it.
It would be ideal if it records the traffic of Jtag pins, I think you understand what I mean
It’s not easy for me to translate back into French all articals on the net, and there are so many different links. (nb: I don’t have a brain of 20 anymore.  LOL)
If you can give me a download link that might work for this type of software  if you think it’s a good idea.
cdt
Online ataradov
    • Personal site
« Reply #23 on: October 23, 2023, 03:18:04 pm »
You need to get a logic analyzer and you will be able to record all the signals. It is a p piece of hardware. There are very common Saleae clones that are <$20. You can also use oscilloscope if you have one.
You can use any MCU board where you can drive a couple pins (like Arduino, but mind 3.3V levels).
Alex
« Reply #24 on: October 24, 2023, 04:11:29 pm »
Hello Ataradov,
Today I demonstrated the USB Blaster
As already said, there is only one CH552 and a regulator.
The regulator is a 3.3V model and supplies the circuit with 3.3V.
Pin 4 is actually not wired (Generally used to power a circuit type 244 to have signal voltages equal in amplitude to the voltage of the circuit under test)
The resistors that go to the signals tms, tclk, tdo, tdi are 22 ohms. (I thought I read in an article that it may be a little weak and that it would take 100 ohms?)
Without considering the design, I looked at the signals one part at the oscilloscope when scan the chain. There is at one time a variation 0/3.3v or reverse.
All seem good...
I installed TOPJtag probe and discovered that there is a small log.
This is where it becomes interesting to read, but for a specialist like you.
We seem to be detecting something, but?
here a part of the most interisting in the log:
TopJTAG Probe 1.7.5, build 1551, May  1 2012
Creating CrUsbBlaster
Loading USB-Blaster FTD2XX interface:
Loading usbblstr32.dll ...  OK
Found 1 USB-Blaster device(s)
Destroying CrUsbBlaster
Creating cable object  ALTERA_USB_BLASTER
Device successfully opened
Initialization succeeded
Analyzing the JTAG chain...
TAP reset
Scan DR...
Bits to be shifted in:
11111111000000000000000000000000+
00000000000000000000000000000000+
000000000000
Bits shifted out:
11000010000000000000000000000000+
000000000000
Checking for all bits are either ones or zeros...
Last 500 bits we received are either only ones or only zeros
JTAG chain NOT found, checking for Atmel ATmega bug...
Received bits have both ones and zeros
IDCODE register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
BYPASS register
.......N Times
BYPASS register
BYPASS register
Some idcode(s) collected
NO JTAG chain found
cdt
