I am torn, but I’m also tight! It’s the first time I’ve used it in about thirteen years. I don’t want to be tied to an expensive platform if I need to do a small bug fix or feature change in three or four years time. Fundsmentally, I still just don’t see it as value for money compared to the alternatives that I battle with.
hopefully you will do plenty of other development in the same tool, during the years between finishing a project and then opening it up again for a feature update!
Assuming it works for all the platforms you are going to be using - you could have a single professional tool that handles all the dev you need, and you are familiar and quick with it because you just know it!
My OP was as much about how crap vendor produced IDEs are in comparison as it was the sticker shock. The $10k could be spent on far more interesting things, like a bit of TE with knobs and buttons and flashing lights on it!
Yes, it definitely could, but if you count how much it might cost in time to use cheaper options, learning whatever the free option is for every different thing you try to work on, maybe you could get more work done with this tool and then use money earned from that to buy more fun tools, too?
