Author Topic: SoC+fpga, over AXI, AMBA bus  (Read 12100 times)
Offline ataradov
    • Personal site
Re: SoC+fpga, over AXI, AMBA bus
« Reply #25 on: February 03, 2016, 07:01:27 pm »
the devicetree just tells what drivers to load and how to configure them
Yep, and this "driver" is just an old way of doing the same. It is only used by a few unsupported boards to specify hardcoded hardware configuration.
Alex
Offline langwadt
« Reply #26 on: February 03, 2016, 07:23:52 pm »
something simple like loading a different configuration for the programmable logic will require that you kill all programs and unload all drivers that might access the axi bus to that logic
Otherwise you will have to write all your software to be able to deal with timeouts. From a programmer point of view, they will have to look like some value (0?) is returned for reads and writes that go nowhere. That is unless you want to handle exceptions.
I'd much rated handle a crashed program/driver or exceptions, than a system that hang until someone hits the reset button
All of this is a hell for a programmer. It is much easier to stop accessing locations before they disappear.
I disagree
Also, ARM implementation of AXI allows you to connect a default slave that handles all unhanded request. Just use that if your implementation allows it.
it won't help the problem is not unhanded request it is transactions that never finish
Offline ataradov
    • Personal site
« Reply #27 on: February 03, 2016, 07:27:29 pm »
What do you mean? If your software makes a request that is not handled by any of thew real slaves, this default slave takes over and completes the transaction.
Of your are saying that your slave disappears right in the middle of the transaction? I don't  think this bus is designed to handle this level of dynamic reconfiguration. I don't think any existing bus can do this. That's just stupid to expect that slave can disappear in the middle of the transaction.
Alex
Offline langwadt
« Reply #28 on: February 03, 2016, 09:38:12 pm »
if the slave disappears during a transaction or isn't there when a transaction is started the system
end up in a a dead lock. Once a master has set xVALID it must wait for xREADY
dynamic reconfiguration is entirely reasonable in a system with configurable logic.
A bus that crashes the whole system waiting forever on something that ought to take microseconds
is silly
Offline ataradov
    • Personal site
« Reply #29 on: February 03, 2016, 09:53:31 pm »
You do whatever you want of course, but don't blame the bus that it does no handle devices disappearing in the middle of transaction. That's just bad system design and there is no need to over complicate the bus logic for things that will never happen in actual real life.
Alex
Offline langwadt
« Reply #30 on: February 03, 2016, 10:17:45 pm »
that's like saying why bother with protected memory or exceptions it is never going to happen in
real life and if it does it is just bad system design
Offline legacyTopic starter
« Reply #31 on: February 10, 2016, 11:15:56 am »
not brilliant, but it's extremely good, this link shows a bit of the magic under the hood: Exploring the Arrow SoCKit Part III - Controlling FPGA from Software   :-+ :-+ :-+
« Reply #33 on: February 20, 2016, 09:01:00 am »
what is the equivalent of De1 in the Xilinx world ? (SoC/ARM + FPGA, with a bus-bridge in the middle)
Offline ataradov
    • Personal site
« Reply #34 on: February 20, 2016, 09:03:22 am »
Any board based on Zynq. Prices vary a lot, so pick whatever fits your bill.
Alex
« Reply #35 on: February 20, 2016, 09:06:06 am »
yes, I meant within the same price as De1, and … is it this one ?
Offline ataradov
    • Personal site
« Reply #36 on: February 20, 2016, 09:08:37 am »
http://zedboard.org/ is one of the most famous. There are many variations with wide rage of prices. Community support is there.
The cheapest one is actually a board from Adapteva, but their site seems to be down at the moment.
Alex
Offline Kilrah
« Reply #37 on: February 20, 2016, 09:35:23 am »
I've got a Zybo, and waiting for my snickerdoodle.
https://www.crowdsupply.com/krtkl/snickerdoodle
Still in preproduction, but it'll be a very cheap entry price.
« Reply #38 on: February 20, 2016, 10:29:58 am »
