I think it's not that latches are per se bad, it's that in HDL it's very easy to get a latch inferred without you realizing it. If you're looking at a device that has a data sheet that starts 'Transparent D-type latch' you choose it only when it is appropriate, whereas with case statements you have to be careful to make sure that you get what you're asking for.
From the compilation report.
Info (10041): Inferred latch for "y[0]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[1]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[2]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[3]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[4]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[5]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[6]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[7]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[8]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[9]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[10]" at Mux_9_bit_32_to_1_behavorial.v(19)
Info (10041): Inferred latch for "y[11]" at Mux_9_bit_32_to_1_behavorial.v(19)
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[0]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[1]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[2]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[3]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[4]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[5]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[6]" is permanently enabled
Warning (14026): LATCH primitive "Mux_9_bit_32_to_1_behavorial:MUX_DUT|y[8]" is permanently enabled
Now I want those because of how I am using the Mux. I don't know what other software is like but Quartus by Altera gives a nice detailed report of stuff like that it. It also tells you any kind of optimizations like, the removal of registers because of redundant or otherwise bad logic (basically the value of the register is always the same so Quartus removes it). With loads of other stuff.
edit: I'm not arguing about the latches, but that, in my experience, there is a load of information provided upon compilation that is sooo helpful.
