Author Topic: LED stops flashing after removing programmer  (Read 7279 times)
Online SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: December 04, 2012, 01:45:15 pm »
I am venturing into the AVR world, after much effort I got a led to flash, so long as the AVRISP2 remains connected (just powered, does not need any PC program running)
What the blinking hell happened ?
Offline dr_p
Re: LED stops flashing after removing programmer
« Reply #1 on: December 04, 2012, 01:53:45 pm »
I don't know AVRs but look into the reset pin and how it works. My PIC used to do that.
  • Global Moderator
« Reply #2 on: December 04, 2012, 01:57:47 pm »
The reset is pulled high with a 10K resistor
Offline dr_p
« Reply #3 on: December 04, 2012, 02:23:46 pm »
You do have external power, right? :D
  • Global Moderator
« Reply #4 on: December 04, 2012, 02:36:59 pm »
yes,
Could it be fuse settings ? maybe the programmer is providing the clock or something ? or I'm in some sort of debug mode ?
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: December 04, 2012, 04:19:05 pm »
It could be the clock that is not running. Check fuse settings
  • Global Moderator
« Reply #6 on: December 04, 2012, 04:32:11 pm »
So the programmer is providing the clock ? this is an atmega48
Offline madworm
« Reply #7 on: December 04, 2012, 04:45:32 pm »
There is _no_ system clock provided via the ISP header.
Make sure the FUSE settings are right (brown-out-reset, clock-source etc.), don't forget decoupling caps.
http://www.engbedded.com/fusecalc
  • Global Moderator
« Reply #8 on: December 04, 2012, 06:07:33 pm »
But oddly the led flashed as directed with the programmer powered as soon as it is unplugged or powered off the led stops, could it be that the watchdog does not work when the programmer is plugged in allowing the program to keep running, but then dose,'t the chip reset on the whatch dog timeout meaning that it would hardly affect a "flasher"
Offline hlavac
  • Country: cz
« Reply #9 on: December 04, 2012, 06:32:44 pm »
Common causes of simple led flashers not working:
- power supply pins not connected (duh! will still run with at least one input high and one low: other circuitry powering it thru protection diodes)
- floating reset pin
- watchdog enabled but not cleared periodically (some bootloaders like the USB DFU in atmega32u4 use watchdog to reset the device, it needs to be disabled in init code even that it is disabled in fuses )
- too low supply voltage & brownout reset enabled
- led pin not set for output properly
- some peripheral overriding the gpio functionality od the pin (like comparator output on some pics)
- floating input pin for button & software loop waiting for it to be released (internal pullup not enabled)
Good enough is the enemy of the best.
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #10 on: December 04, 2012, 06:43:30 pm »
I suggest you do a 'sanity check' by probing round all the pins with your scope. That will answer a lot of guesses like reset line level, power and ground, oscillator running etc.
  • Global Moderator
« Reply #11 on: December 04, 2012, 07:41:43 pm »
good idea, but to clarify, this DOES flash the led with the programmer connected, it stops when the programmer is removed, so it's not something like loss of power etc. The circuit is powered.
  • Global Moderator
« Reply #12 on: December 04, 2012, 07:46:21 pm »
just removed the programmer wires one by one and now it keeps flashing ! removed power, shorted power leads on chip (discharging the by pass cap) put power back and now it DOES work, what was that all about ? why does the chip need "weaning" off the programmer ?
Offline madworm
« Reply #13 on: December 04, 2012, 08:26:16 pm »
Normally it doesn't.
Is this on a breadboard?
The only occurrence of erratic hardware-based (resets) AVR behaviour I've observed so far was caused by a broken brown-out module - a bad chip. Under normal conditions a floating reset pin shouldn't be an issue (internal pull-up), but who knows what environment you're in.
Offline Jon Chandler
    • Throw Away PIC
« Reply #14 on: December 04, 2012, 09:17:09 pm »
Is there a voltage regulator on the board?  I had similar troubles once when the DC input voltage to the regulator was marginal.
  • Global Moderator
« Reply #15 on: December 04, 2012, 10:22:33 pm »
nope running it off a 5 Volt mains adapter
Offline TriodeTiger
« Reply #16 on: December 04, 2012, 11:04:11 pm »
Erm, you sure it's 5V regulated and won't jump around? Maybe the programmer provides a cleaner source from the USB, jumping to wallwart takes a sec to regulate and cuts out...schematic would help...
« Last Edit: December 05, 2012, 12:27:46 am by TriodeTiger »
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline Psi
« Reply #17 on: December 04, 2012, 11:08:50 pm »
This thread needs a pic of the circuit
« Last Edit: December 04, 2012, 11:13:20 pm by Psi »
  • Global Moderator
« Reply #18 on: December 05, 2012, 07:03:05 am »
well it is still working, turned it off last night and back on this morning and it works fine. Maybe the problem was diconecting the programmer from usb while it remained connected to the AVR ?
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #19 on: December 05, 2012, 09:37:37 am »
Could very possibly be. You can't really rely on those sort of things that are 'off' to be in any state you expect them to be in.
  • Global Moderator
« Reply #20 on: December 05, 2012, 12:34:39 pm »
Of course, maybe the programmer was holding the chip in reset
Offline Kremmen
« Reply #21 on: December 05, 2012, 01:05:23 pm »
I didn't see a mention of what processor specifically you are using. Anyway, The AVRISP uses the 6 pin ISP interface and specifically the reset signal to connect to several types of AVR processor. For some more modern chips the reset pin is the actual data line for single wire debugging. If you power the AVRISP down but keep it connected it is very possible that the reset line is pulled low, preventing the processor from starting at all.
Nothing sings like a kilovolt.
Dr W. Bishop
Offline deephaven
    • Deephaven Ltd
« Reply #22 on: December 05, 2012, 01:28:58 pm »
As I mentioned earlier, a quick scope probe round all the pins would remove some of the mystery.
Offline Kremmen
« Reply #23 on: December 05, 2012, 01:56:29 pm »
Yes sure, but if we think specifically why disconnecting the programmer allows the chip to function, this is the likely reason as far as i understand.
Dr W. Bishop
  • Global Moderator
« Reply #24 on: December 05, 2012, 02:11:06 pm »
ATmega48
