Author Topic: LEXI3 ESP32-D/U/S & S3 Modular Breadboards and Power Supply  (Read 220 times)
Offline Lexter333Topic starter
« on: March 22, 2025, 08:51:38 pm »
I’ve been getting a little fed up with trying to create projects using the ESP32 microcontrollers on standard breadboards so I decided to design my own  ;D. I’m absolutely made up with the result and they work perfectly. I thought I’d share them with you, if you have a 3D printer that is. They are just like any other board now. You have 4 points per pin now on a single breadboard. Just to make it a little better, I decided to make them modular, giving the user the ability to create massive projects. I also created a power supply that connects to the modules.
If you have a 3d printer, take a look:
LEXI3 ESP32-D/U & S Breadboard - https://cults3d.com/en/3d-model/various/lexi3-esp32-d-u-s-wroom-32-30-38-pin-modular-breadoard-joiners
LEXI3 ESP32-S3 Breadboard - https://cults3d.com/en/3d-model/various/lexi3-esp32-s3-wroom-32-44-pin-modular-breadoard-joiners
LEXI3 Power Supply - https://cults3d.com/en/3d-model/various/lexi3-power-supply-for-esp32-modular-breadboard-joiners
LEXI3 ESP32 250 POINT EXTENSION BOARD - https://cults3d.com/en/3d-model/various/lexi3-250-point-esp32-breadboard-extension-board-joiners
