A little help with a problem guys,
I bought a couple of purple lgt8f328p nano clone boards (w/ 16mhz crystal) for some projects, and face this:
All sketches run OK right after i upload them from arduino IDE, but (some) will not auto run later on power-on.
They run only if i reset the board (press the onboard reset switch).
The program for the project i work on now is here:
https://github.com/crescentvenus/EF-Lens-CONTROL/tree/masterbut this happens with all programs i tested trying to troubleshoot (mostly programs using an ssd1306 so i get an easy visual).
PS1. a simple program such as blynk runs ok without the need for reset.
PS2. i run the oled on 5V, so it can't be power shortage on the board's 3.3V line.
Is it the code? is it the oled, or the board?
I know very little about programming, i am just into projects so any help is welcome.
Any ideas?
