Author Topic: little querry to get an output to flip/flop  (Read 14273 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: October 10, 2011, 11:58:52 am »
So I have a project I am already using the PWM output but i need another oscillating output that is no available on the pic I'm using. The program will run in a cycle that coincides with each PWM cycle so I had a thought, using basic as the language, have a "bit" type variable and add 1 to it each time I get round to "that" line of the program, in this way I should get a 0 1 0 1 0 1 0 1..... output, right ? or is there another way of doing it with complicated program lines, I just need a toggling output, frequency and duty are not much of a problem.
Offline Jimmy
Re: little querry to get an output to flip/flop
« Reply #1 on: October 10, 2011, 12:09:03 pm »
You will have to turn it on and off you can turn it on at the beginning and off half way through your program to output what you want
  • Global Moderator
« Reply #2 on: October 10, 2011, 12:14:52 pm »
I could do, i just wondered if I had a single bit variable 0 = 0, 0+1=1, 1+1=0, 0+1=1 etc
Offline joelby
« Reply #3 on: October 10, 2011, 12:19:19 pm »
Can you use a byte type and invert it each time, and then use the lowest bit (foo & 0x01)? You could increment a byte variable too, but using an adder seems like overkill for just toggling a bit.
Offline jimmc
« Reply #4 on: October 10, 2011, 12:44:24 pm »
Exclusive OR with a '1' in the bit position you want to toggle will toggle the bit as you require.
Jim
  • Global Moderator
« Reply #5 on: October 10, 2011, 12:47:08 pm »
I think the timed set or reset bit program lines will be simpler, silly thought I can up with over lunch
Offline PeterG
« Reply #6 on: October 10, 2011, 12:59:55 pm »
Wich BASIC language are you using?
Proton?
Regards
Testing one two three...
  • Global Moderator
« Reply #7 on: October 10, 2011, 01:00:46 pm »
mikroe-basic, I keep vowing to learn C but just never find the time
Offline PeterG
« Reply #8 on: October 10, 2011, 01:06:10 pm »
ok, i am thinking you have a few options.
Instead of using +1, i would use NOT to flip the bit.
The timing can be handled by either the pics timer or use a pair of Delay statements.
Regards
  • Global Moderator
« Reply #9 on: October 10, 2011, 01:17:29 pm »
ah yes that will do it nicely
Online Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: October 10, 2011, 04:49:32 pm »
why dont you go direct to asm? C is "harder" than asm, much things are out of your control, just like basic. and asm is much closer relation with the mcu. people may argue :P
  • Global Moderator
« Reply #11 on: October 10, 2011, 04:51:52 pm »
 It is because of a number of assholes on another forum insisting that asm which i could not master was the only way and that nearly put me off electronics all together and caused a 2 year delay in my achieving anything in microcontrollers !
Offline cyberfish
« Reply #12 on: October 10, 2011, 07:53:22 pm »
ASM is suitable for some jobs, but for 95% of other things, C is much more suitable.
ASM makes introducing bugs easier, takes a lot longer to write, and the code a lot harder to read and maintain. Don't use ASM unless necessary.
Online IanB
« Reply #13 on: October 10, 2011, 08:23:14 pm »
This is a crazy opinion.  :o
people may argue :P
Indeed they may.   ???
Online IanB
« Reply #14 on: October 10, 2011, 08:26:18 pm »
The simplest idiom in a language like BASIC is this:
x = 0
while (forever)
  x = 1 - x
end
  • Global Moderator
« Reply #15 on: October 10, 2011, 08:51:58 pm »
The usual argument is that asm is faster, well my little 12F micro @ 4MHz can keep up with a car engine and more running a basic program so I can't see why i need asm in there
Online Zero999
  • 0999
« Reply #16 on: October 10, 2011, 09:24:02 pm »
On the PC, I found assembly easier to learn than C which just made me want to give up.
I've used BASIC before but never on an MCU.
I've only done a little programming on MCUs and used assembler which I found quite straightforward.
Offline Bored@Work
« Reply #17 on: October 10, 2011, 10:00:45 pm »
And why do you think that single data point, if true, is sufficient to generalize?
Online Zero999
  • 0999
« Reply #18 on: October 10, 2011, 10:32:18 pm »
I'm not.
Online IanB
« Reply #19 on: October 11, 2011, 02:10:56 am »
If you "understand" computer hardware then assembly is easy (if tedious); otherwise it is not. However, C is like high level assembly, so if you don't "understand" computer hardware at an intuitive level then C is also hard to learn. On the other hand if you are comfortable with assembly then programming in C should be like a walk in the park.
BASIC is in a different language family, quite deliberately so. Computers are supposed to be labour saving devices, and if BASIC saves on labour compared to C then  program in BASIC and be happy!
Offline Psi
« Reply #20 on: October 11, 2011, 02:16:57 am »
Programming windows apps in C  is much harder than C programming for a microcontroller.
The Windows API is full of objects, structures and weird callback routenes which can be very annoying to get your head arround when starting out.
You end up writing lots of boring API code just to 'tell' windows to create you a form.
Of course modern IDE's often generate a lot of that code for you, so it's not too bad, but the code is still visible in your editior and gets in the way of following your actual code logic.
When coding a microcontroller in everything is so much simpler. There is no OS API to interface with (unless you create one).
Microcontroller code is normally quite easy to read and understand, even if you have limited skills in the language.
After all, an IF and a LOOP is pretty easy to figure out in almost any language.
(The obvious exception is ASM, where you really have to know the language to be able to read it)
One thing you do need to understand when working with microcontrollers is bitwise operations and how use them. They're used far far more in microcontroller programming than windows programming.
« Last Edit: October 11, 2011, 02:29:58 am by Psi »
Online Mechatrommer
  • Country: my
« Reply #21 on: October 11, 2011, 02:23:20 am »
here we go again
i'm not insisting, its just only suggestion since the OP did mention vb vs c
  • Global Moderator
« Reply #22 on: October 11, 2011, 05:40:22 am »
well I'm not sure how C compares to BASIC, I thought it was about as easy/hard to learn, maybe not ?
Online Mechatrommer
  • Country: my
« Reply #23 on: October 11, 2011, 06:03:48 am »
same
Online IanB
« Reply #24 on: October 11, 2011, 06:09:05 am »
BASIC was designed to make it easy to get results out of a computer--designed help make writing programs fast and convenient. There have been many varieties of BASIC since the first one but all of them have had the same philosophy, a classic example being Microsoft Visual Basic. Visual Basic is the archetypal "get results fast" language.
On the other hand C was designed to get "close to the metal". Everything about the language was intended to give you complete and full control over the hardware at the level of pointers, memory and data bits. It was intended to let you write every program you could write in assembly, only more easily.
So easy/hard to learn is relative, but I would have to say in general that BASIC is easier to learn than C.
