Author Topic: Looking for a USB Type C - SPI (or serial) bridge - recommendations?  (Read 15022 times)
Offline funkathustra
Re: Looking for a USB Type C - SPI (or serial) bridge - recommendations?
« Reply #25 on: August 04, 2017, 09:05:58 pm »
I [...] am seriously considering using Mini-B due to all the issues I've experienced using micro USB in consumer devices. You see all these articles and studies where micro is better / last longer but reality seems to be otherwise.
We ran into issues with USB cables and dev boards that we used for several years with hundreds of students. We did a ton of experiments and testing with different setups, and the TL;DR is essentially "of course USB mini appears more reliable; it's not used for anything these days with high insertion rates"
Here's what we concluded:
  • Most problems with USB micro can be traced to old cables that people have used every day for five years or longer with several generations of smartphones. These cables have probably seen thousands of insertion cycles.
  • There are lots of really cheap USB micro cables out there, and these have a high failure rate. When we switched from $1 bulk USB micro cables to $4 name-brand ones, all our problems went away with bad cables.
  • USB mini connections appear to be more reliable these days, but our hypothesis is that most USB mini cables people have laying around these days were never used daily with smartphones — and instead, have only been used with dev boards. Most of these cables have probably less than 50 insertion cycles on them.
  • When we've used USB mini receptacles on boards that have similar use to USB micro receptacles, the minis fail more quickly
« Last Edit: August 04, 2017, 09:08:45 pm by funkathustra »
The following users thanked this post: abraxalito, sporadic
Offline sporadic
    • forkineye.com
« Reply #26 on: August 04, 2017, 09:45:37 pm »
You bring up some good points, appreciate it.  Thanks!
Offline alm
« Reply #27 on: August 05, 2017, 01:57:10 am »
That makes sense. USB micro-B is rated for many more insertions than mini-B. And micro-B was designed so the cables fail before the connector fails.
Offline westfw
« Reply #28 on: August 05, 2017, 11:49:22 am »
Care to name names?  Especially for the "good" $4 cables?
There are a LOT of cheap, bad, cables out there, and no one is likely to want to spend $15/cable.
I expect USB-C cables to have the same quality problems, except that even the cheap cables will be more expensive.
« Reply #29 on: August 06, 2017, 06:06:20 pm »
I wasn't involved in the purchasing process, but I'm almost positive that we went with Anker cables — might have worked directly with them, or just bought them from Amazon/eBay.
So far, my favorite USB-C cables for USB 2.0 applications are the Cable Matters ones — they're $6 on Amazon, have a great matte feel, super thin cable, and have gold-plated connectors that are a lot stricter-tolerance than other cables, which means they never lose a connection — even when subjected to a ton of lateral force. They have the most satisfying "click" I've heard, too, which gives me a ton of confidence for more rugged applications.
Just remember: the great thing about USB-C and the worst thing about USB-C are one in the same: it's one connector to rule them all. Those simple USB 2.0 A-to-C cables are going to be worthless for connecting actual USB 3.1-capable devices (external hard drives, capture cards, etc) to your computer. For that, you'll need a more expensive, bulkier USB 3.1 A-to-C cable that actually has all 22 signals bonded out.
Offline westfw
« Reply #30 on: August 10, 2017, 08:46:21 pm »
Good to know, I guess.
Recent facebook post from tech-savvy (network engineer) friend:
does anyone actually make a micro-usb cable that lasts. I now have a pile of anker high end cables that have died in under six months of use each
Offline Monkeh
« Reply #31 on: August 10, 2017, 10:26:07 pm »
Does anyone make a user who doesn't destroy cables needlessly? I've used the same ones daily for years.
Offline hermit
« Reply #32 on: August 10, 2017, 10:34:33 pm »
The only one I have 'destroyed' is a cheap 10 footer.  It will charge but I can't transfer data.
Offline Monkeh
« Reply #33 on: August 10, 2017, 11:19:21 pm »
The only one I've destroyed I haven't dared test - it got left on the back of a chair and fell into a loose joint. It's very flat now.
Offline judge
« Reply #34 on: June 22, 2020, 06:49:30 pm »
Very old thread I know, but good info on it. One thing I saw on a recent design was use of a connector like this: https://gct.co/files/drawings/usb4105.pdf
Interested to know people’s opinions of this design, which is specific to USB-C/USB 2.0
Offline lucazader
« Reply #35 on: June 22, 2020, 08:21:31 pm »
We use them in out designs. Or at least something similar with a similar footprint.
The ones that we have sourced are quite reliable. good connector feel and work really well for our application.
They have the USB-2.0 data lines as well as the CC lines. They should also have the SBU lines as well in case you are considering using them.
Offline PCB.Wiz
« Reply #36 on: June 23, 2020, 04:34:33 am »
Full thru hole stakes on USB-Micro seems to have improved since this thread started, and this is a good example
https://lcsc.com/product-detail/USB-Connectors_XKB-Enterprise-U254-051N-4BH806_C319170.html
Type C connectors seem to still be a premium price, but do offer higher current ratings
https://lcsc.com/product-detail/USB-Connectors_Jing-Extension-of-the-Electronic-Co-Jing-Extension-of-the-Electronic-Co-USB-3-1-C-16PF-SMT2-0Type_C167321.html
Offline NorthGuy
« Reply #37 on: June 23, 2020, 05:11:27 pm »
Care to name names?
I bought several assorted UGreen USB cables on AliExpress. They all were good.
