Author Topic: Low resource audio encoder and decoder  (Read 2866 times)
Online ali_asadzadeh
« on: November 27, 2018, 04:23:32 pm »
Hi, I have used helix mp3 decoder before, for my new project I have this limitation that I have a 200Kbits total bandwidth for my network, I have a cortex M4 with a  100MHz clock, so I want to know if there are some open source C library’s that would decode and encode the audio, so it can be done both the decode and encode the audio with 16bit’s data and at least 20K samples per second Realtime with the M4. So, the audio would be small enough to pass the network bandwidth, the MP3 decoder source is available, the problem with it is the encoder is not available as open source also it uses lots of CPU cycles to encode and decode at the same time, and it’s an over compression for this project. Any ideas are welcome!
I'm a Digital Expert from 8-bits to 64-bits
Offline mark03
Re: Low resource audio encoder and decoder
« Reply #1 on: November 27, 2018, 04:51:31 pm »
You might look into Ogg Vorbis rather than MP3.  As ogg is a much more open spec, you'll probably have a greater chance of finding a ready-to-go MCU implementation.
If good performance at lower data rates is important, I believe Opus is the current reigning champion.  Also an open design, likely with an open-source MCU implementation already in existence.  IIRC it really shines at rates < 100 kbps.
Offline SiliconWizard
« Reply #2 on: November 27, 2018, 05:23:30 pm »
You should specify what your goal is in terms of acceptable loss.
There are many lossy data compression schemes for audio that lead to high compression ratios (higher than MP3) and take little processing power, if you don't care too much about sound quality.
You may be interested in Opus: https://opus-codec.org/
« Reply #3 on: November 27, 2018, 06:42:50 pm »
Thanks do you know any encode and decode library? can it be done with a M4 @ 100Mhz?
The audio quality is not my main concern, as it 's used mainly for speech, but the better quality always sound better ;)
Offline mark03
« Reply #4 on: November 27, 2018, 06:56:35 pm »
Actually, both Opus and Vorbis result in better quality than MP3, at moderate bit rates.  MP3 is only still around because of inertia and ubiquity.  (There is a reason none of the recent video codecs use MP3 for audio.  Although they're not using Opus or Vorbis either for the most part, which is a different story having more to do with vested patent interests and $$ than technical merit.)
I would use a targeted google search of github, and also look at each codec project's own source distribution.  I'm almost certain one of them comes with a Cortex M branch... probably Opus.
« Reply #5 on: November 27, 2018, 07:17:21 pm »
For speech, you can take a look at the Speex codec: https://www.speex.org/
Or implement any ADPCM codec, I'm sure there's plenty of source code out there.
Offline mark03
« Reply #6 on: November 27, 2018, 08:35:54 pm »
TI app note "Implementing Opus voice code for TM4C129x device":
https://www.ti.com/lit/an/spma076/spma076.pdf
(This is a Cortex-M4-based device.)
Offline David Hess
  • DavidH
« Reply #7 on: November 28, 2018, 03:43:14 am »
In the past MP3 encoding and decoding could be done in real time on a Pentium 90 so it should be possible on an M4 which has single cycle DSP.
« Reply #8 on: November 28, 2018, 06:03:24 am »
Thanks to all.
thanks for the link :) ;)
