Hello,
I have a project which requires MCU to generate data and send it at high speed to an FPGA. ARM Cortex core is a requirement.
The intended way how this is supposed to work is
-processor generates data and places into an array
-timer interrupt initiates a transfer from the data array to GPIO.
-DMA is expected to - once set up- transfer one chunk of data of fixed size (16 bits) to GPIO and advance the DMA address register to another cell in the array
-DMA stops at the end of array and this has to be able to generate interrupt for the processor to know that it has to repopulate the array
Now the problem is, that GPIO<->DMA transfers seem to be largely omitted by chip manufacturers. I have found a mention, that some LPC families allow such transfer as memory-to-memory transfer into the address space occupied by GPIO registers, but I couldn't find any particular code example or application note that would confirm that. On top of that I'm kind of biased towards STM32 family.
So the question here is: do you know of any widely available, open-source/free toolchain friendly Cortex-M3 or M4 MCU that you know for sure that can do this kind of thing? I would prefer something from bigger players like ST, NXP, TI, Atmel.
