Author Topic: Padauk PMS15A: even cheaper MCU (1.2 cents!)  (Read 802 times)
Offline gir
  • Country: at
« on: April 08, 2019, 06:42:51 am »
So, I just discovered that Padauk outdone themselves and created an even smaller and cheaper variant of the PMS150C, the PMS15A. The P150-series datasheet was updated to v1.06 to include the PMS15A on 2019-03-27 and is not present in v0.04 (2018-01-24).
Main (only?) difference to the PMS150C is the ROM size (.5KW vs 1KW).
The only seller I've found that (apparently) sells them is on 1688.com, which I have no experience with. There it is listed at .09yuan in qty 100, equalling roughly 1.2 cents. I'm wondering if/when other suppliers (especially LCSC) will have those new ones in stock.
Datasheet: http://www.padauk.com.tw/upload/doc/PMS15A,PMS150C%20datasheet%20V106_EN_20190327.pdf
Product Info: http://www.padauk.com.tw/en/product/show.aspx?num=105
Seller (SOP-8 only): https://detail.1688.com/offer/41229073536.html
« Last Edit: April 08, 2019, 06:50:47 am by gir »
The following users thanked this post: oPossum, thm_w
Offline spth
Re: Padauk PMS15A: even cheaper MCU (1.2 cents!)
« Reply #1 on: April 24, 2019, 06:30:32 am »
AFAIR Puolop (they sell devices using the same architetcure as Padauk) has a device with 0.75 KW of ROM.
