Author Topic: [SOLVED] building a metalbare cross compiler from scratch (custom configured)  (Read 8787 times)
Offline legacyTopic starter
hi guys
I need to compile gcc, target=mips-be (host=arm-le, I can native compile under Qemu/Arm)
I am a bit confused by the GNU documentation, the following is my current-build-script
VERSION=v4.4.3
export TARGET=mips-idp-elf
export PREFIX=/usr/$TARGET
export PATH=$PATH:$PREFIX/bin
target=build/$TARGET-gcc-$VERSION
echo "building gcc"
rm -fr $target
mkdir -p $target
cd $target
../../src/gcc-$VERSION/configure \
         --target=$TARGET \
         --prefix=$PREFIX \
         --disable-libssp \
         --without-headers \
         --with-float=soft \
         --without-newlib \
         --with-gnu-as \
         --with-gnu-ld\
         --disable-nls \
         --disable-threads \
         --disable-shared \
         --disable-libssp \
         --enable-languages=c
make all
make install
I need to compile
  • a crosscompiler
  • C language only
  • target=mips big endian
  • profiled for metalbare (no OS)
  • I do not need any newlibc (by Cygnus/RedHat) or glibc(by GNU) or whatever (1)
(1) I do not need any newlibc or glibc or whatever, because i have to use my C runtime (crt0) and my BSP, which already includes the full support for libc
* * * My questions * * *
  • 1) is the configuration correct? Do I miss something?
  • 2) is there a way to reduce the time needed to complete the build-phase? I have seen the compiler is rebuild 3 times  :-//
  • 3) I do not like the "install-path" (see the following), I'd like to have
    • 3.1) { cc1, collect2 } installed in "/usr/mips-idp-elf/bin2" instead of "/usr/mips-idp-elf/libexec/gcc/mips-idp-elf/4.4.3/", how to do so ?
    • 3.2) I do not need "/usr/mips-idp-elf/lib/*", and I'd like to have it installed in "/usr/mips-idp-elf/lib" instead of "/usr/mips-idp-elf/lib/gcc/mips-idp-elf/4.4.3/", how to do so ?
    • 3.3) I'd like to have include-path installed in "/usr/mips-idp-elf/include", how to do so ?
# ls /usr/mips-idp-elf/
bin/          include/      info/         lib/          libexec/      man/          mips-idp-elf/ share/
 # ls /usr/mips-idp-elf/libexec/gcc/mips-idp-elf/4.4.3/
cc1            collect2       install-tools/
 # ls /usr/mips-idp-elf/lib/gcc/mips-idp-elf/4.4.3/
crtbegin.o     crti.o         el/            include-fixed/ libgcc.a       soft-float/
crtend.o       crtn.o         include/       install-tools/ libgcov.a
thank you in advance  :-+
edit:
I forgot: mips-binutils already compiled and installed in "usr/mips-idp-elf"
no problem with them  :-+
« Last Edit: November 04, 2015, 09:45:16 am by legacy »
Re: looking for GCC GURU, building gcc-mips, cross compiler, tricks needed
« Reply #1 on: November 03, 2015, 03:45:42 pm »
I am studying gnu dot org configure, but …  :-//
Online nctnico
« Reply #2 on: November 03, 2015, 04:05:30 pm »
AFAIK compiling GCC from scratch = world of pain
I'd look for a known-good build script or pre-build toolchain and go from there. There are options to make gcc/ld ignore the standard libraries and startup files. I recommend to use a prebuild GCC and use those options for bare metal work.
Offline andersm
« Reply #3 on: November 03, 2015, 04:17:07 pm »
Whatever reasons you think you have for breaking the toolchain are not valid.
« Reply #4 on: November 03, 2015, 04:50:30 pm »
unfortunately it's not already existing, and what exists doesn't satisfy my needs, so I have to recompile  :palm:
(I am not a GNU fan, so you can understand I am not happy to have to deal with their sources, but I have to)
« Reply #5 on: November 03, 2015, 04:54:03 pm »
could You answer my specific questions instead?
« Reply #6 on: November 03, 2015, 05:06:36 pm »
( specifically host=armv5tejl-linux-gnueabi )
Offline janoc
« Reply #7 on: November 03, 2015, 05:12:42 pm »
Hello,
I haven't built GCC for mips, but I did compile it for AVR and ARM before. So take my opinion with a grain of salt.
VERSION=v4.4.3
echo "building gcc"
rm -fr $target
mkdir -p $target
cd $target
         --target=$TARGET \
         --prefix=$PREFIX \
         --disable-libssp \
         --without-headers \
         --with-float=soft \
         --without-newlib \
         --with-gnu-as \
         --with-gnu-ld\
         --disable-nls \
         --disable-threads \
         --disable-shared \
         --disable-libssp \
make all
make install
    I need to compile
    • a crosscompiler
    • C language only
AFAIK, the config above will build a native compiler (i.e. something that will run on a MIPS machine), not a crosscompiler. You need to add the --host option for that.
You can look here for instructions and cherrypick the relevant bits (they are compiling a toolchain targetting Linux on MIPS, though - different TARGET):
https://www.linux-mips.org/wiki/Toolchains
Then just don't compile newlib/glibc.
If I remember right, GCC builds first a bootstrap compiler, then it uses that to compile the gcc version you want to build and finally uses the self-compiled gcc to rebuild itself to ensure correctness. So no, from this point of view there isn't a way to speed it up.
What you can play with is to ensure that flags such as -pipe are set, that will avoid using temporary files between preprocessor and compiler and compiler and assembler, using pipes instead. I wouldn't recommend doing parallel build (make -j X, where X is the number of parallel builds you want) unless the GCC doc says this is OK - the GCC build is very complex and things could go wrong if it is not adapted for parallel compilation.
No idea how to do this - you may have to hack on the makefiles. I suggest that you ask on the GCC mailing list, because GCC expects these files in certain places and if you change the path it could break stuff.
« Reply #8 on: November 03, 2015, 05:13:41 pm »
  PID USER      PR  NI    VIRT    RES    SHR S %CPU %MEM     TIME+ COMMAND
 2544 root      40   0   52112  35812    272 R 99.2 58.4  18:53.71 genattrtab
also I am not happy with "genattrtab", because it eats more than 180Mbyte of ram during the gcc-buildup  :palm: :palm: :palm:
( I add to add 1Gbyte of ram to Qemu/arm, in order to reduce the swap size, which is handled to the virtual hard drive ---> too slow)
« Reply #9 on: November 03, 2015, 05:19:48 pm »
it works perfectly!
as I wrote above the whole build up is invoked under Qemu/Arm!
so host=arm by default, host=arm, target=mips ---->it's a cross compiler!!!
Yes, but you have to specify if you need support (new lib? I have forced --no-xxx), and I also want to avoid libgloss to be compiles: I do not need it!
so --disable-bootstrap isn't working? :palm:
OK
« Reply #10 on: November 03, 2015, 05:24:03 pm »
it works perfectly!
see the log
building gcc
checking build system type... armv5tejl-linux-gnueabi
checking host system type... armv5tejl-linux-gnueabi
checking target system type... mips-idp-elf
Offline Lukas
    • carrotIndustries.net
« Reply #11 on: November 03, 2015, 09:10:57 pm »
Have you tried buildroot? I managed to make it produce a working mips gcc some time ago with little effort.
« Reply #12 on: November 03, 2015, 09:59:58 pm »
does it solve my specific questions ?
« Reply #13 on: November 03, 2015, 10:09:14 pm »
subscribed to  - gcc-digest at gcc dot gnu dot org -
Offline dgtl
  • Country: ee
« Reply #14 on: November 03, 2015, 10:29:28 pm »
Why not using crosstool-ng? It helps with a kernel-style menuconfig menu configuring all of the options you might otherwise not think of.
« Reply #15 on: November 03, 2015, 10:58:03 pm »
because it does not matter with my purpose!
Offline janoc
« Reply #16 on: November 03, 2015, 11:00:29 pm »
it works perfectly!
Ah okay, my bad. You are right, of course.
=> GCC mailing list, that is a fairly non-standard setup.
You didn't have --disable-bootstrap in your configure options if I see correctly. Furthermore, I wouldn't recommend that, because the compiler you may have on your host may not be able to build the gcc - e.g. some commercial Unix systems come with a really ancient compiler and the bootstrap was designed to overcome this.
If you are building on Linux with a reasonably recent gcc it will probably work, but it is better to be safe than chase weird bugs because some obscure code got optimized wrong.
However, if I understand this page correctly: https://gcc.gnu.org/install/build.html
the bootstrapping is used only for building native compilers, not a crosscompiler. So this could be a moot point.
On the other hand, they say that parallel building is possible, so you may want to try make -j X build. However, if you are building in QEmu, it will likely not help much - there the bottleneck is the emulated CPU and amount of RAM and a parallel build will only make things go even slower.
Offline janoc
« Reply #17 on: November 03, 2015, 11:05:49 pm »
Before you yell at people I suggest you actually look at those tools - both buildroot and crosstool-ng. Both are designed to do what you are attempting to do and it is possible that the things you are looking for are configurable there. Worth checking them out, IMHO, instead of trying to reinvent the wheel.
People are trying to help you here, mate.
« Reply #18 on: November 03, 2015, 11:52:06 pm »
yes, it's slower, no help from the j-flag when you are under QEmu (and see how much memory it eats  :palm: :palm: :palm: )
I am manually trying different options (I have asked the right combination to GNU email list)
the GNU documentation is not so clear to me too, their sources appears too bloated, which is confusing  :-//
I am really afraid I have to hack the Gcc's Makefile to force things
or probably I'd better hack the binary "gcc" in order to force the "collector" to point to the wanted-path
"cc1" is the C compiler, "gcc" invokes it, so I could, eventually trash "gcc" and build my-own version of the "collector"
I already have my builder (already tested), so a project work-flow will look this way
  • { list of file.s } ----> GNU.as ( my FLAGs ) ----> { list of file.o }
  • { list of file.c } ----> GNU.cpp (1) --> GNU.cc1 ( my FLAGs ) ----> {{ list of file.o } + { list of file.S }} ( I want to see the assembly level )
  • { { list of file.o } + myBSP + myLIBC.o + myCRT0.o } ---> GNU.ld ( my flags + linker script + memory model ) ---> binary (elf+debug symbols)
  • binary.elf ---> GNU.objdump (strip) ---> motorola/s19
no doubt that it's a bit crude, but it looks like a practical solution to have everything under control ( including paths )
and it avoids me to waste too much time understanding whatever is GNU-skilled-only  :-+
(1) GCC has a number of phases to its compilation, and it uses different internal commands to do each phase.
C in particular is first preprocessed with cpp, then is compiled into assembly, assembled into machine language, and then linked together.
cc1 is the internal command which takes preprocessed C-language files and converts them to assembly.
It's the actual part that compiles C
Interesting read about Gcc's Architecture
« Last Edit: November 04, 2015, 10:42:07 am by legacy »
« Reply #19 on: November 03, 2015, 11:59:17 pm »
ups, I forgot to tell you about that
QEmu-arm # gcc -v
Using built-in specs.
COLLECT_GCC=/usr/armv5tel-softfloat-linux-gnueabi/gcc-bin/4.8.4/gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/armv5tel-softfloat-linux-gnueabi/4.8.4/lto-wrapper
Target: armv5tel-softfloat-linux-gnueabi
Configured with: /var/tmp/portage/sys-devel/gcc-4.8.4/work/gcc-4.8.4/configure --host=armv5tel-softfloat-linux-gnueabi --build=armv5tel-softfloat-r
Thread model: posix
gcc version 4.8.4 (Gentoo 4.8.4 p1.6, pie-0.6.1)
Offline janoc
« Reply #20 on: November 04, 2015, 09:13:13 am »
Silly question, but do you need to host the compiler on that particular (and ancient - ARM5? Whoa - are you planning to compile on a Sharp Zaurus?) architecture? If you could compile on real hw (e.g. in native Linux or at least in a fast Linux VM like VirtualBox), it would certainly be a lot faster.
Even if you need to host on ARM, a newer system running on something like Raspberry Pi or BananaPi (or one of the many ARM Linux SBCs available now) would be probably much faster than the emulation in Qemu.
BTW, why are you fighting with the paths? The ones that GCC uses by default are semi-standard and other tools may actually depends on them. I wouldn't move things around unless I had a very good reason for that. The scheme GCC uses is there to permit having multiple compiler versions installed side-by-side. Wouldn't a bunch of symbolic links post install solve your problem? (I assume you only want the path changed for convenience). That's probably a lot easier and safer than hacking binaries or the build system where one doesn't understand all the dependencies.
« Reply #21 on: November 04, 2015, 09:47:49 am »
faster than QEmu/ARM on multi core i7 machine  :-DD :-DD :-DD :-DD ?
Solved !!!
it works great on QEmu/ARM
two solutions, two branches, mutual exclusive
  • hacked "gcc.c", forcing all the paths I need (and I need it this way for my reasons, no time to say why/what/where)
  • removed "gcc", swapped it with my "collector", it's a piece of software I have developed, it does the same job of "gcc" (as collector)
edit: lesson learnt from GNU.gcc's configure
  • prefix
  • gcc_exex_prefix
  • C_include_path
in the theory they allow you place the compiler pieces in any location
practically(1) they get embedded within "gcc.c", in the "collector" part
In order to be sure that things get built as I expected:
I had better change and modify "gcc.c" immediately
this is my conclusion!
(1) note these can be used as environment variables to move things around
even on a already built and working compiler, so …
… they might cause troubles to the host's toolchain (it's not clear WHY?)  :palm: :palm: :palm:
« Last Edit: November 04, 2015, 12:43:07 pm by legacy »
Offline janoc
« Reply #23 on: November 04, 2015, 11:32:48 pm »
Did you benchmark it? If you are hitting swap at 1GB of RAM in the emulator, I think it will be faster if you take a physical, not emulated HW and 2GB of RAM. Qemu is very slow compared to native code. I would be very surprised if even multicore i7 was able to run it at near native speeds.
I do not have any RPI/BananaPI/whatever on hand, and no time to buy/reallocate one of them in the lab
while the customer wants a copy of the whole building system (which should run on PC), so it's not the point
about what I could to to improve my results: I simply assigned less than 256Mbyte of ram to QEmu (my mistake)
and due to the fact that gcc-build-up eats a lot of ram (more than 512Mbyte if you enable "pipe" instead of "temp files")
the kernel was swapping on /dev/sda1, which was a bottleneck, and assigning 1Gbyte of ram to QEmu improved results
Offline janoc
OK. Well, you could always deliver the build system on an SD card and with its own computer :)
Yeah, 256MB, that's no good - gcc is a huge amount of code, even on a PC with 4GB of RAM the machine will struggle. RAM is by far the most important thing there.
