The 8-pin DIPs (LPC810)
I never understood purposes of such devices.
I'm just a hobbyist , so i like DIP's.
I find it quite usefull, allthough i must admit that the DIP prob. isn't going to be the all time high seller.
My guess is that NXP had the "DIP mold" , and they're targeting "EDU Classes & Breadboards" that get familiar with the chip, and later the (now finished) EE's uses NXP in their designs.
For the 800 series i like 3 things :
1: It can "single cycle" toggle a gpio pin , meaning 30Mhz IO speed and 32bit bit operations.
Combined with the 8 bit pattern match engine , and advanced bitmask regs. This can be a "logic chip" substitute.
2: It has a "real" 32bit timer (SCT) , everyone should have one (I always loved NXP for their timers)
I'll use it for a "jitterfree" 10Mhz down divider (Thunderbolt) ie. 1PPS,50Hz etc.
3: Arm-GCC has float & double (ie. AVR only has float) , makes some PID or DDS dividerwords easier to calc.
Easier as in you don't have to do the calc with integer math.
That said ... I do like the DIP-28.Pin 1114 even better , but do admit that DIP's aren't going to be the top source of NXP's income.
Edit: I'll still use AVR's for things that doesn't require any of the above "skills" , you don't need a cannon to shoot a bird.
/Bingo
