I worked on this 2 years ago and haven't been back, but...
* Mutex protection in low_level_input etc not needed according to here
* https://community.st.com/s/question/0D73W000001P2M3SAK
* __dmb not needed according to https://community.st.com/s/question/0D73W000001PMYnSAO
This is my eth input - it uses polling since that avoids all kinds of issues, and in my system (most embedded systems actually) it is plenty fast enough
* This function is the ethernetif_input task. It uses the function low_level_input()
* that handles the actual reception of bytes from the network interface.
* This is a standalone RTOS task so is a forever loop.
* Could be done with interrupts but then we have the risk of hanging the unit with fast input
* (unlikely if ETH is via a switch, but you could have a faulty LAN with lots of
* broadcasts) plus we have the issue of link status change detection in a thread-safe way.
void ethernetif_input( void * argument )
struct pbuf *p;
struct netif *netif = (struct netif *) argument;
uint32_t link_change_check_count = ETH_LINK_CHANGE_COUNT;
// Define RX activity timer, for dropping fast poll down to slow poll
TimerHandle_t *rxactive_timer = xTimerCreate("ETH RX active timer", pdMS_TO_TICKS(ETH_SLOW_POLL_DELAY), pdFALSE, NULL, RXactiveTimerCallback);
// Start "rx active" timer
xTimerStart(rxactive_timer, 20); // 20 is just a wait time for timer allocation
do
p = low_level_input( netif ); // This sets rxactive=true if it sees data
if (p!=NULL)
if (netif->input( p, netif) != ERR_OK )
pbuf_free(p);
if (rxactive)
rxactive=false;
// Seen rx data - reload timeout
xTimerReset(rxactive_timer, 20); // Reload "rx active" timeout (with ETH_SLOW_POLL_DELAY)
// and get osDelay below to run fast
rx_poll_period=ETH_RX_FAST_POLL_INTERVAL;
// This has a dramatic effect on ETH speed, both ways (TCP/IP acks all packets)
osDelay(rx_poll_period);
// Do ETH link status change check
link_change_check_count--;
if (link_change_check_count==0)
// reload counter
// Get most recently recorded link status
bool net_up = netif_is_link_up(&g_netconf_netif);
// Read the physical link status
ethernetif_set_link(&g_netconf_netif);
// Has the link status changed
if (net_up != netif_is_link_up(&g_netconf_netif))
ethernetif_update_config(&g_netconf_netif);
if (net_up) {
// Link was up so must have dropped
debug_thread_printf("Ethernet link down");
else {
// Link was down so must be up - restart DHCP
debug_thread("Ethernet link up");
network_restart_DHCP();
} while(true);
The link status detect is important
* @brief This function is called on change of link status
* to update low level driver configuration.
* @param netif: The network interface
* Called from ethernetif_input if there was a link change.
static void ethernetif_update_config(struct netif *netif)
__IO uint32_t tickstart = 0;
uint32_t regvalue = 0;
if(netif_is_link_up(netif))
/* Restart the auto-negotiation */
if(EthHandle.Init.AutoNegotiation != ETH_AUTONEGOTIATION_DISABLE)
/* Enable Auto-Negotiation */
HAL_ETH_WritePHYRegister(&EthHandle, PHY_BCR, PHY_AUTONEGOTIATION);
/* Get tick */
tickstart = HAL_GetTick();
/* Wait until the auto-negotiation will be completed */
do
HAL_ETH_ReadPHYRegister(&EthHandle, PHY_BSR, ®value);
/* Check for the Timeout ( 1s ) */
if((HAL_GetTick() - tickstart ) > 1000)
/* In case of timeout */
goto error;
} while (((regvalue & PHY_AUTONEGO_COMPLETE) != PHY_AUTONEGO_COMPLETE));
/* Read the result of the auto-negotiation */
HAL_ETH_ReadPHYRegister(&EthHandle, PHY_SR, ®value);
/* Configure the MAC with the Duplex Mode fixed by the auto-negotiation process */
if((regvalue & PHY_DUPLEX_STATUS) != (uint32_t)RESET)
/* Set Ethernet duplex mode to Full-duplex following the auto-negotiation */
EthHandle.Init.DuplexMode = ETH_MODE_FULLDUPLEX;
else
/* Set Ethernet duplex mode to Half-duplex following the auto-negotiation */
EthHandle.Init.DuplexMode = ETH_MODE_HALFDUPLEX;
/* Configure the MAC with the speed fixed by the auto-negotiation process */
if(regvalue & PHY_SPEED_STATUS)
/* Set Ethernet speed to 10M following the auto-negotiation */
EthHandle.Init.Speed = ETH_SPEED_10M;
else
/* Set Ethernet speed to 100M following the auto-negotiation */
EthHandle.Init.Speed = ETH_SPEED_100M;
else /* AutoNegotiation Disable */
error :
/* Set MAC Speed and Duplex Mode to PHY */
HAL_ETH_WritePHYRegister(&EthHandle, PHY_BCR, ((uint16_t)(EthHandle.Init.DuplexMode >> 3) |
(uint16_t)(EthHandle.Init.Speed >> 1)));
/* ETHERNET MAC Re-Configuration */
HAL_ETH_ConfigMAC(&EthHandle, (ETH_MACInitTypeDef *) NULL);
/* Restart MAC interface */
HAL_ETH_Start(&EthHandle);
else
/* Stop MAC interface */
HAL_ETH_Stop(&EthHandle);
ethernetif_notify_conn_changed(netif);
// Called from ETHIF thread. Detects link change and resets the link state.
static void ethernetif_set_link(struct netif *netif)
// Read PHY_BSR
regvalue &= PHY_LINKED_STATUS;
// Check whether the netif link down and the PHY link is up
if (!netif_is_link_up(netif) && (regvalue))
/* network cable is connected */
netif_set_link_up(netif);
else if (netif_is_link_up(netif) && (!regvalue))
/* network cable is disconnected */
netif_set_link_down(netif);
You can see the link change is detected by the PHY chip (LAN8742 etc) and this needs to be used to stop other things hanging.
But this stuff is so complex... and LWIP was done c. 15 years ago and everybody who worked on it has long since moved on, so there are no support forums for it, and the API descriptions are mostly useless unless you already know the answer. It works solidly though.
On the ST forum there is a super clever guy calling himself Piranha, but he feeds on people less clever than himself (IQ below 200) which is OK - I don't mind being insulted if I get a solution - but he rarely posts a complete solution to anything.
Which CPU are you using? I believe there are working sources for the H7.
Thank you for your response and for providing the solutions (though it seems that the links to the two ST forums cannot be opened).
I am using LwIP in two NXP microcontrollers (Kinetis MK64 and I.MX RT1170), and it seems that NXP's SDK team has addressed some bugs in LwIP. For MK64, this microcontroller went into mass production in 2015, and the SDK has been discontinued for years. The program freezing issue I encountered occurs on this chip. Its ethernetif_input is as follows:
* This function should be called when a packet is ready to be read
* from the interface. It uses the function ethernetif_linkinput() that
* should handle the actual reception of bytes from the network
* interface. Then the type of the received packet is determined and
* the appropriate input function is called.
* @param netif the lwip network interface structure for this ethernetif
void ethernetif_input(struct netif *netif)
struct pbuf *p;
LWIP_ASSERT("netif != NULL", (netif != NULL));
/* move received packet into a new pbuf */
while ((p = ethernetif_linkinput(netif)) != NULL)
/* pass all packets to ethernet_input, which decides what packets it supports */
if (netif->input(p, netif) != ERR_OK)
LWIP_DEBUGF(NETIF_DEBUG, ("ethernetif_input: IP input error\n"));
pbuf_free(p);
p = NULL;
Meanwhile, the I.MX RT1170 is currently NXP's flagship chip, so the SDK updates are timely, and it seems that they actively address bugs in LwIP. The implementation of ethernetif_input is also quite different from MK64 (similarly, STM32 may also have some maintenance for LwIP bugs).
* @param netif_ the lwip network interface structure for this ethernetif
void ethernetif_input(struct netif *netif_)
#if ETH_DO_RX_IN_SEPARATE_TASK
(void)netif_;
if (__get_IPSR())
portBASE_TYPE taskToWake = pdFALSE;
xTaskNotifyFromISR(ethernetif_rx_task, netif_to_bitmask(netif_), eSetBits, &taskToWake);
if (taskToWake == pdTRUE)
portYIELD_FROM_ISR(taskToWake);
else
(void)xTaskNotifyGive(ethernetif_rx_task);
#else
fetch_all_received_pkts(netif_);
#endif /* ETH_DO_RX_IN_SEPARATE_TASK */
static void fetch_all_received_pkts(struct netif *netif_)
struct pbuf *p;
while ((p = ethernetif_linkinput(netif_)) != NULL)
if (netif_->input(p, netif_) != (err_t)ERR_OK)
LWIP_DEBUGF(NETIF_DEBUG, ("fetch_all_received_pkts: IP input error\n"));
ethernetif_pbuf_free_safe(p);
p = NULL;
The macro definition ETH_DO_RX_IN_SEPARATE_TASK is enabled by default, processing Ethernet packets in another task(In fact, it also calls the fetch_all_received_pkts function). The function fetch_all_received_pkts here is similar to ethernetif_input in MK64, but the function for releasing pbuf appears to be thread-safe based on its name. If you're interested, you can download this SDK from NXP's SDK Dashboard.
This reminds me that in the future, when encountering problems, I may consider referring to the SDKs of different semiconductor manufacturers.
My next project will use this chip. I'll see if the SDK for this chip have already addressed this issue.
