Hi Ataradov,
I need your suggestion on improving range for Our time sync network. Right now, we are able to connect 8 to 10 end nodes to Receiver. Within 70m range, we see less than 1% samples missing for over 1 hour capturing. When we increase the distance about 100m, we see the disconnectivity between Receiver and Endnodes.
So,We are thiniking of implementing Gateway between endnodes and Receiver.
Question:
Right now,at the end of one cycle of 200ms, Receiver receives 8x100 bytes (8 End nodes each have 20ms time slot sending 100 bytes in their time slot). In the case of implementing Gateway, I need to store these 800 bytes in the Gateway and have to send them in the Gateway time slot(for example 9th device at 180ms) to Receiver.
As we know, RF212B has only 128 bytes transmit buffer.But, Gateway requires buffer of minimum 800 bytes...I don't know whether my statement is right or not..
Please suggest..
Regards,
Muthu
