Hello, I’m using Arduino Uno to interface MAX7219 8x8 dot matrix display with 4 modules. Can someone reccomend a way to fit 6 digits on 4 modules that would display clock as for example 12 : 34 : 56. The default “font” using MAX7219 or parola library is to big and I can’t find a way to size it without writing my own code from the beginning.
See
https://arduinoplusplus.wordpress.com/2016/11/08/parola-fonts-a-to-z-defining-fonts/.
You have 32 LEDs horizontally. I'd use
H H H · h h h h · · · M M M M · m m m m · · · S S S S · s s s s 1 = 0x01
H H H · h h h h · · · M M M M · m m m m · · · S S S S · s s s s 2 = 0x02
H H H · h h h h · X · M M M M · m m m m · x · S S S S · s s s s 4 = 0x04
H H H · h h h h · · · M M M M · m m m m · · · S S S S · s s s s 8 = 0x08
H H H · h h h h · · · M M M M · m m m m · · · S S S S · s s s s 16 = 0x10
H H H · h h h h · X · M M M M · m m m m · x · S S S S · s s s s 32 = 0x20
H H H · h h h h · · · M M M M · m m m m · · · S S S S · s s s s 64 = 0x40
H H H · h h h h · · · M M M M · m m m m · · · S S S S · s s s s 128 = 0x80
The data displayed on the four MAX7219 modules is formed from 32 bytes, each byte defining one (vertical) column of LEDs. Each LED corresponds to a binary digit, the values shown above on right.
You essentially need five 8×3 glyphs –– space, ':', '0', '1', '2' –– and eleven 8×4 glyphs –– space, and '0' through '9'. You need to draw these yourself, I'm afraid.
