Author Topic: MCU hangs when performing a reset from software  (Read 1290 times)
Offline newtekuserTopic starter
« on: October 16, 2023, 12:10:44 am »
Hello All,
I am trying to reset my PIC16F887 from software to no avail. Have tried disabling i2c, disabling interrupts and timers, but my MCU hangs when calling the RESET function. What am I doing wrong?
The setup is fairly simple consisting of a 16x2 LCD and DS3231 chip connected to the micro-controller. I also have a push button connected to the external interrupt INT0 pin (RB0).
void reset()
    INTCONbits.GIE = 0;
    PIE1bits.TMR1IE = 0;
    INTCONbits.INTE = 0;
    INTCONbits.PEIE = 0;
    T1CONbits.TMR1CS = 0;
    T1CONbits.TMR1ON = 0;
    SSPCON &= 0xDF;
    RESET();
Thanks!
Offline DavidAlfa
Re: MCU hangs when performing a reset from software
« Reply #1 on: October 16, 2023, 03:22:34 am »
IIRC there's no reset instruction in the pic16, so the program actually makes a jump to reset vector, not a good way to reset.
https://onlinedocs.microchip.com/oxy/GUID-BB433107-FD4E-4D28-BB58-9D4A58955B1A-en-US-5/GUID-06B80226-9C00-4067-B659-E0D3760CDA94.html
You could use the WDT for a real reset:
void reset()
    OPTION_REGbits.PSA = 0;    // Make sure the PS prescaler is not used for the WDT
    WDTCON=1;  // pre = 32, WDT on
    while(1);  // wait for reset (About 1ms)
« Last Edit: October 16, 2023, 03:41:14 am by DavidAlfa »
The following users thanked this post: Ian.M, Doctorandus_P, newtekuser
« Reply #2 on: October 16, 2023, 03:28:16 am »
To issue a true reset you could configure the WDT for the shortest time and start it (Inside the reset function).
Afterwards stay forever in a while (1); loop until the watchdog resets the device.
That's very clever, many thanks!  :-+ I'll try it out.
Offline jpanhalt
« Reply #3 on: October 16, 2023, 09:17:14 am »
If you switch to the very similar with respect to code enhanced midrange PIC, e.g., 16F1829, you will have a RESET instruction.  That might be of use, if for some reason you  need to distinguish a WDT reset from something done in code, e.g., user initiated reset.
Offline DavidAlfa
« Reply #4 on: October 16, 2023, 11:15:59 am »
You can still detected the reset reason in the 887 (Brown-out, WDT, etc).
Offline DavidAlfa
« Reply #5 on: October 16, 2023, 02:14:49 pm »
Now I arrived home I could check what RESET() actually does. It's defined in xc8debug.h :
#if defined(_PIC14E) || defined(_PIC14EX) || defined(_PIC18)
#define RESET() asm("reset")
#else
#define RESET() asm("ljmp $")
#endif
asm("ljmp $") jumps to current PC address, basically a while(1);, that explains why it was hanging.
Maybe it was expecting the WDT to be active? Meh, just don't use it in PIC16!  ::)
« Last Edit: October 16, 2023, 02:25:22 pm by DavidAlfa »
