Author Topic: MCU Selection for BLE and battery device  (Read 2968 times)
Offline joeyjoejoeTopic starter
« on: December 05, 2024, 09:36:36 pm »
I'm looking to make a simple BLE button that will run off a single coin-cell or two AA's.
I've done a lot of work with the ESP32, but the low-power modes are still pretty "bad". I suppose I could put in a self-latching circuit.
nRF and STM come to mind - is there anything else I should be looking at?
Thanks in advance!
Offline SiliconWizard
Re: MCU Selection for BLE and battery device
« Reply #1 on: December 05, 2024, 10:27:03 pm »
If your device only has a low duty cycle (like, it wakes up every few minutes), the ESP32 (at least C3 and C6, probably S3 as well) can still be used. Just use their standby mode, they draw as little as 5 µA in standby.
Granted they're not as good as others in that the standby mode requires a full boot to wake up (which can last as long as about 500 ms), but if again it wakes up infrequently, that's still fine. If you were considering using an external power switch to power it down, then clearly you'd be in the same boat anyway. So no need for that. Just put them in standby. They can even retain some RAM in standby.
If you want something that wakes up much faster and don't require a reboot, then yes, forget about them. There are tons of candidates these days. If you want something with integrated RF supporting BLE, then one of the lowest power of all is the Ambiq Apollo 3 Blue. It's not even expensive at all. You can also consider the nRF52 series as well, very good. OnSemi RSL10/15. The STM32L4/L5/U5 are very low power too and pretty good but don't come with integrated RF. There is the STM32WB series, with integrated RF, but I have no experience with those. They're probably a good fit too.
« Reply #2 on: December 05, 2024, 10:55:50 pm »
Thanks!
Yeah the STM32WB looks cheap and good enough, and 8nA in shutdown, 1uA in "deepstop" mode. Has a nucleo board as well so I could play with it first before making a design.
« Reply #3 on: December 05, 2024, 10:59:29 pm »
One benefit of the STM32 compared to the others I listed is indeed the availability of very cheap dev boards.
« Reply #4 on: December 05, 2024, 10:59:59 pm »
Figuring out their product lines is another thing :)
Offline tszaboo
« Reply #5 on: December 06, 2024, 11:43:15 am »
Creating a simple Bluetooth Low Energy (BLE) button that can operate on low power is an exciting project!
Thank you totallynotchatgpt. Can you tell me how to make a cupcake ?
Offline pcprogrammer
« Reply #6 on: December 06, 2024, 11:53:19 am »
Maybe a recipe for an egg roll. Not sure if cupcake's are common in China.
Somebody is trying to sell their goods via this forum. At least they provided a long list with possible options for the OP to choose from.  :-DD
Offline tellurium
  • Country: ua
« Reply #7 on: December 06, 2024, 04:26:03 pm »
Love ST's dev boards!
Though their Nucleo boards have those long buttons
Those buttons always  break, however ST is very consistent with using them all the time
Open source embedded network library https://github.com/cesanta/mongoose
TCP/IP stack + TLS1.3 + HTTP/WebSocket/MQTT in a single file
« Reply #8 on: December 06, 2024, 10:27:38 pm »
Can I ignore the 32kHz crystal on STM32WB05xZ ? Data sheet says 32Mhz is a must, it uses the words "can" for 32kHz. I assume this is maybe for RTC or some sort of low power wakeup, but if I am just going to trigger my wakeup from a physical switch, perhaps I can skip?
This will be my first STM design so a fun learning exercise.
Offline tszaboo
« Reply #9 on: December 06, 2024, 11:45:24 pm »
Design it in build the prototype with it. I you can write the code without it then leave it off the production boards.
« Reply #10 on: December 06, 2024, 11:57:32 pm »
A 32.768 kHz crystal for the LSE oscillator is always optional on all STM32's.
But I thought you were going to buy a dev board? I really suggest testing what needs tested on it first and designing your own board afterwards.
Online Smokey
  • Not An Expert
« Reply #11 on: December 07, 2024, 01:01:39 am »
How many do you plan on making?  If it's a volume product then you might want to make different choices than if you are making a couple widgets for yourself.
Offline amyk
« Reply #12 on: December 07, 2024, 03:33:57 am »
Take a look at JieLi's SoCs, if you can figure out how to use them they're ridiculously cheap and found in a ton of other BLE products.
« Reply #13 on: December 07, 2024, 02:34:09 pm »
I had thought about trying to get into that game. But I'm unsure if it will be worth the hassle?
Nucleo is in the shopping cart for sure to play around, the design happens in parallel :) Damn, the BOM count for the STM32WB is tiny if you want bare bones! Are all the STM's like this? It looks like VDD, some decoupling caps and a crystal and you're done! The SMPS is optional.
« Reply #14 on: December 07, 2024, 10:33:03 pm »
Unless you want to design something ultra tiny, just place the footprint for a 32k crystal and if it's of no use, just don't populate it.
Yes, all STM32 only require a few bypass caps (number depending on the package) and even the crystal is often not required unless you have critical timings. (If it include a RF front-end, a crystal will almost always be required, but otherwise, not necessarily.) But that's the case for most other vendors as well?
Offline betocool
« Reply #15 on: December 09, 2024, 10:39:41 am »
Hey, I've been using an NRF52 for a project lately, it works very well. Didn't get it into the lowest power modes, but that's beside the point, I didn't really try!
Documentation and examples are pretty good, and the NRF forum is very supportive, unlike the STM32 one. Support tools for Android devices and bootloader are also pretty good.
Downsides, the IDE is a bit hit and miss sometimes, and it uses Zephyr as its OS. I got used to it, but I try to avoid it. Too Linux-y for a microcontroller IMHO.
Cheers,
Alberto
« Reply #16 on: December 09, 2024, 01:16:56 pm »
That is too bad, but it does look like PlatformIO supports the NRF series to some degree at least so I could avoid that.
Offline glenenglish
  • RF engineer. AI6UM / VK1XX . Aviation pilot. MTBr
« Reply #17 on: December 26, 2024, 05:00:55 am »
Suggest Rowley Associates IDE /debugger tools for STM32  if you want something  decent and pro.
https://www.rowley.co.uk/arm/index.htm
Offline __george__
  • Country: no
« Reply #18 on: December 26, 2024, 09:09:15 pm »
The dev board for the Ampiq Apollo 3 blue costs around 150 euros! I checked their SDK page and it ends up in their contact page. Do you need an NDA to use their SDK?    ???
« Reply #19 on: December 26, 2024, 09:36:52 pm »
You just need to create an account on their web site, at least that's what I did. https://contentportal.ambiq.com/login
Download the AmbiqSuite SDK.
Yes their dev boards are not cheap, but their MCUs themselves are pretty cheap OTOH. You can consider third-party boards - Sparkfun has a dev board that is pretty cheap: https://www.sparkfun.com/products/16828
Offline __george__
  • Country: no
« Reply #20 on: December 26, 2024, 10:27:18 pm »
Glad to know that you don't need an NDA and for the suggestion, the sparkfun seems pretty good indeed  :-+
Offline nimish
« Reply #21 on: December 28, 2024, 12:17:59 am »
RSl15 is decent for this. Exceptionally low sleep current. Has a module from murata too.
