Author Topic: Measure current and voltage via ADC  (Read 3234 times)
Offline powermosfetTopic starter
« on: June 01, 2012, 05:09:19 pm »
How to measure current and voltage using microcontroller ADC input.
voltage range is up to +11v and current is about 5 amps.
I use a voltage divider to get the voltage
Vi=11V
RA=1k2
RB=1k
Vo=RB/RA+RB*Vi  -> with about .2 error
are there any better ways to protect the microcontroller input?
thank you.
« Last Edit: June 01, 2012, 05:24:22 pm by powermosfet »
Offline Erwin Ried
  • Country: no
Re: Measure current and voltage via ADC
« Reply #1 on: June 02, 2012, 12:29:17 am »
Have you seen http://www.ebay.com/itm/5A-range-Current-Sensor-Module-ACS712-Module-NEW-/130704791796?pt=LH_DefaultDomain_0&hash=item1e6e9cd8f4 this kind of modules?
I bought ones but I never used them (I am using a small coil with a TA-220) to do the same
My website: http://ried.cl
