Author Topic: ESP8266 - 18 Bit ADC - MCP3421 - I2C Driver  (Read 3492 times)
Offline TJ232Topic starter
  • www.esp8266-projects.org
    • ESP8266 Projects
« on: April 06, 2015, 07:39:03 am »
   After testing the ESP8266 Internal ADC - http://www.esp8266-projects.com/2015/03/internal-adc-esp8266.html let's see also a higher resolution ADC at work.
   The MCP3421 is a single channel, low-noise, high accuracy delta-sigma A/D converter with differential inputs and up to 18 bits of resolution in a small SOT-23-6 package. The on-board precision 2.048V reference voltage enables an input range of ±2.048V differentially.
   The device uses a two-wire I2C compatible serial interface and operates from a single power supply ranging from 2.7V to 5.5V, has a decent price and looks like a good companion for our ESP8266 module.
For more details : http://www.esp8266-projects.com/2015/04/18-bit-adc-mcp3421-i2c-driver-esp8266.html
Videos:
 1. Test done in filtered environment - stable voltage
2. Test done in noisy environment - using real bus unfiltered ?voltage
3. Test done in noisy environment - values are printed directly on CBDB DevBoard LCD Display?
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline Muxr
Re: ESP8266 - 18 Bit ADC - MCP3421 - I2C Driver
« Reply #1 on: April 07, 2015, 02:51:52 am »
Relatively cheap too. Nice!
