Author Topic: Micro Controller, FPGA or ??, I need USB HS and alot of analog  (Read 14488 times)
Offline thewyliestcoyoteTopic starter
I am working on a project that needs some analog bandwidth. It is a RF transceiver so everything is IQ sampling. What I would like to find is something with at least 2 5MSps ADC and 2 matching DAC's and high speed USB. More bandwidth is better, but that is about all I need. Cost is a big factor so I am not sure there are many FPGA's that make it as none have build in ADC's and DAC's and there does not seem to be any cheap ADC's and DAC's. FPGA would also require the use a ULPI chip.
I have looked at the ST micro's and can't seem to find anything
STM32F3:
    pros:
         2 5 MSps ADC's
         2 4.5 MSps DAC's
    cons:
         Only USB FS
STM32F4:
    pros:
         2 10 MSps DAC's
         USB HS host and device
    cons:
         2 2.4 MSps ADC's(This is 12 bit mode, it 8 bit mode it is closer to 3.2 MSps)
Atmel does not seem to have any micro's with 2 high speed DAC's.
Freescale seems to have DAC's limited to mostly audio type stuff.
I know Lattice and some of the other FPGA vendors have some low cost devices but I think the cost of an external ADC and DAC is to high.
By chance does any one know of a single device that can meet my specs or a low cost ADC and or DAC that can?
Thanks,
Wylie
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Micro Controller, FPGA or ??, I need USB HS and alot of analog
« Reply #1 on: April 05, 2015, 11:23:39 pm »
DACs are pretty rare on MCUs - if you give up looking for that onboard,  that may give you more options.
FPGA cost will be very much down to what you need to do - costs can be from $1 to $1000!
For USB HS, something like an external FTDI FTx232H may be an option.
Microchip's PIC32MZ may be worth a look - quick glance at headline specs shows 28MSPS ADC, DSP instructions, HS USB and a buttload of RAM
But check errata carefully - early devices had lots of issues.
Day Job: Mostly LEDs
« Reply #2 on: April 05, 2015, 11:51:04 pm »
I have seen the PIC32MZ's. Cost and board space are at a premium so I would like a onboard DAC. That said I agree 100% the DAC and ADC should not be onboard. Noise and quality are much better.
I should have described the project up front. I am trying to create a cheap half duplex SDR with up to 80MHz-6GHz and +4MHz of analog bandwidth for a student lab. I am trying to keep it under $75 a unit. Also the size should be about that of a large USB flash drive. This is why I am trying to get all the USB and baseband stuff onto one chip.
Offline BlueBill
« Reply #3 on: April 06, 2015, 12:17:04 am »
Why not just buy a FunCube? The cost of a from scratch solution would be more.
« Reply #4 on: April 06, 2015, 12:49:58 am »
Transmitter, frequency range, bandwidth, and so on. I need the frequency range and bandwidth for things like channel effects and multipath. Transmission so a student could implement their own protocol.
What I really need is a RTL-SDR that can transmit, bandwidth of 4 MHz, and a frequency range of 80MHz to 6GHz.
« Last Edit: April 06, 2015, 12:53:02 am by thewyliestcoyote »
Offline Rasz
    • My random blog.
« Reply #5 on: April 06, 2015, 01:19:52 am »
funcube is $200 .....
cheapest SDR with tx is, or rather will be if it ships, HackRF Blue at ~$200
check out LPC4370 if you want great ADC (80mhz 12bit), airspy sdr uses it successfully
has everything but the DACs
http://www.lpcware.com/content/project/application-example-using-lpc4370-and-labtool-hardware
super cheap devboard 15 euro, full demo board with analog frontend 100 euro
http://www.lpcware.com/lpclink2
http://www.embeddedartists.com/products/lpcxpresso/lpclink2.php
this arm will let you get rid of cpld and adc/dac combo from hackrf, probably ~$20 lower bom right there
« Reply #6 on: April 06, 2015, 01:33:27 am »
I have the LPC4370 board. It is a bit over kill. That said it would be nice to have a IF at 20MHz and digitally down convert it. This was there is no LO leakage into the signal.  Also the LPC4370 only has one ADC so there is going to be some skew or imbalance in I and Q. The HackRF design is a little more then that is needed here. I am doing a lot of tricks to save cost on the RF sections. Also the HackRF has a bit of a problem as some of the maximum parts seem to be coming up on the end of life(#ThanksMaximIntegrated).
Offline codeboy2k
« Reply #7 on: April 06, 2015, 02:06:48 am »
<rant>
Grrr... USB terminology... I still can't get my head to remember which is faster, HS, FS, LS, SS
(LS) Low Speed (USB 1.1, USB 2.0) rate of 1.5 Mbit/s (187 kB/s) joysticks.
(FS) Full Speed (USB 1.1, USB 2.0) rate of 12 Mbit/s (1.5 MB/s)
(HS) Hi-Speed (USB 2.0) rate of 480 Mbit/s (60 MB/s).
(SS) Super-Speed (USB 3.0) rate of 4.8 Gbit/s (600 MB/s).
What happens at 10Gb/s ? Ultra-Speed? what about 20 Gb/s.
The 90's and nought's tripped me up all the time with SCSI, FAST-SCSI, WIDE-SCSI, ULTRAWIDE, FASTWIDE, ULTRA160, ULTRA320, grrrr...
I started to get the ULTRA speeds once they started adding bit rates.
USB should just be USB-<speed>
USB-1.5, USB-12, USB-480, USB-4800, USB-10k, etc..
Enough with the marketing names.
</rant>
« Reply #8 on: April 06, 2015, 03:30:29 am »
ERROR missing closing tag of type "speed"! lol
I am not sure when they are going to move off of just using on-off type keying. They are hitting the limit for frequency dispersion of the materials in the cables to make some sort on-off keying reasonable to equalize.
I think Transcend has a trademark on USB ultra speed so that maybe interesting to see how that one plays out.
@BlueBill
I really do like the idea of the funcube. One of the big headaches I am sure to have is USB drivers. The funcube solved that problem is a very awesome way of just using USB audio device protocol. That will not get me up to 4MHz of bandwidth in any reasonable way.
Offline rx8pilot
« Reply #9 on: April 06, 2015, 04:19:47 am »
This one should be able to help. May need to tweak the budget somewhat. Still need outboard ADC/DAC's I think.
http://www.digikey.com/product-detail/en/XC7V2000T-G2FLG1925E/XC7V2000T-G2FLG1925E-ND/3981901
« Reply #10 on: April 06, 2015, 05:15:10 am »
HAHA I LOVE IT!!! one chip is more than my years income as a student. And even better yet it is Xilinx so you know the tools are more expensive than the parts. I bet I could do DDS of 6GHz bandwidth of spectrum with that and good ADC's and DAC's. Order better yet just toggle the IO so fast it generates all 6GHz of spectrum at the same time. I think that one chip is about 10 times the project budget for all materials.
Offline hans
« Reply #11 on: April 06, 2015, 07:11:34 am »
You may want to double check the STM32 datasheets. According to what I can find, the STM32F407/429 DAC is only an 1MS/s maximum DAC for small changes and a typ. 3us settling time for 10-bit codes +/- 4LSB of end value.
PIC32MZ are plagued by errata, and especially the ADC was a bummer. Initially they announced a 28MSPS ADC, but now dropped it down to basically PIC32MX specs - 10-bit 500ksps.
Offline andersm
« Reply #12 on: April 06, 2015, 07:32:50 am »
The resolution has been downgraded to 8 bits in the latest errata sheets.
Offline Rasz
    • My random blog.
« Reply #13 on: April 06, 2015, 10:23:24 am »
everything has one adc with multiplexers, besides Airspy manages just fine
what was the name of that other cheap sdr with tx? the one using cable modem frontend - that could be a good strategy for you, whole frontend in one chip, makes it 3 chip design (frontend, dac and LPC4370)
« Reply #14 on: April 06, 2015, 10:27:58 am »
Really? damn that is kind of a deal killer for a lot of applications. I wounder what happened. That is a big difference between initial claims and what it can do.
They have a app net on getting more out of the DAC's. AN4566 Extending the DAC performance of STM32 micro controllers. See page 7 table 2 indicates 10.5 MSps for the DAC. This difference in performance is from the high output impedance of the DAC and the expectation of some capacitance loading on the output. This can be over come by the use of a external buffer or amplifier in the form of a op amp.
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00129215.pdf
I have never heard of this is. Can you provide some information more about it? or where to find out more?
Offline Rasz
    • My random blog.
« Reply #15 on: April 06, 2015, 11:43:26 am »
sample and hold, its not like it samples them in turns :)
3g, not cable modem  :palm: :)
bladeRF and LMS6002D
doable as a DIY project for students in a class:
$25 frontend
$10 LPC4370
leaves you $35 for dac and pcb
osh park 4 layer 150 inches2 = $300, lets make is a 12inch2 boards = $25 per pcb. (No idea if you need 4 layer in the first place)
now to find a $10 DAC and you are set
« Reply #16 on: April 06, 2015, 06:06:25 pm »
$25 frontend
$10 LPC4370
While i like the idea of students having to build something, I am not sure It would fly in this case. You know how schools are about building stuff.
I is likely to become a 6 layer board and something better than FR4 or FR408. That last part is still maybe but likely. To get 50 ohms on a trace from OSH park is a large trace and for a 4 layer layer it is a small trace. The distance from the outer layer to first inner is 6.7 mils.
$10 for a DAC is on the higher side of the physable cost for a part.
Offline tggzzz
« Reply #17 on: April 06, 2015, 06:28:51 pm »
Look at the Red Pitaya. TL;DR version is that it is a programmable 100MS/s oscilloscope and analogue controller, based on FPGA and dual-core ARM A9s
« Last Edit: April 06, 2015, 06:51:27 pm by tggzzz »
Offline hans
« Reply #18 on: April 06, 2015, 06:43:46 pm »
I see, they basically try to keep the load impedance down for faster edges.
May want to point at the note that dropped down onto the next page, in which the 10.5MSPS is reached with an "empty" AHB bus. May be wise to just put the ADC and DAC to work via DMA on a STM32F4 discovery board if you decide to go this route, and see how it performs + if there is any jitter/latency issues.
From memory I've had some issues with DMA on the STM32F4, where the delay of a ext. timer trigger to actual SPI clock toggling at 17-odd MHz was in the order of hundreds of nano-seconds.
« Reply #19 on: April 06, 2015, 07:40:28 pm »
I dont think that is what I want. It looks like a great scope but going back to what I need it to do and cost. It will not function as a transmitter in much of any of the frequency ranges that I need. Cost at $460 is way too much for this application.
They have a app net on getting more out of the DAC's. AN4566 Extending the DAC performance of STM32 micro controllers. See page 7 table 2 indicates 10.5 MSps for the DAC. This difference in performance is from the high output impedance of the DAC and the expectation of some capacitance loading on the output. This can be overcome by the use of a external buffer or amplifier in the form of a op amp.
Yeah I don't think there is any other way of doing this other than using the DMA's for the ADC's and DAC's. There maybe some very very small DSP done on the device(Things like burst tagging for GNURadio). I dont need 10.5 MSps for each DAC, I just need about 4 to 5 MSps for each DAC. Also I am not running the ADC's at the same time as this device is just half duplex.
As for the jitter there is not much else the device is doing so I don't think this will be much of a problem. I maybe able to even run the DAC's and ADC off of the CPU in place of using the DMA. This would leave the USB being the only DMA. Jitter of hundreds of nano-seconds could be a deal killer. I have a couple of STM32F3 and STM32F4 demo boards on order and I will investigate.
Offline Howardlong
« Reply #20 on: April 06, 2015, 08:10:23 pm »
$25 frontend
$10 LPC4370
Good luck making a board with an LPC4370 fanout that OSHPark can fab. You will need to go down to max 5 mil track and gap, and 12mil drill, and be creative. Been there.
The PIC32MZ is one of the biggest disappointments in my electronics career, I unwisely put a product on hold based on the promising PIC32MZ's ADC spec. When I finally got silicon, several months late, I just couldn't get the ADC  to perform. The support from Microchip was deafening by its silence, in the UK their sales people knew nothing about the devices, and they weren't interested in helping me despite having a reasonable record of buying tens of thousands of PIC24 and PIC32s with them. In the end I threw in the towel, but I lost about nine months' development time as a result, and went with the LPC4370, which has been a very steep learning curve, but it works. You can get around the single s/h with either (a) your own s/h [reasonably hard at this sample rate!], (b) all pass filter, or (c) in host software with, say, a fast convolution.
« Reply #21 on: April 06, 2015, 10:57:39 pm »
$25 frontend
$10 LPC4370
I had not planned on using OSH park for any finished devices and not because I don't like the service. Their specs just don't work for microwave circuits. The 6.7 mil layer of pregrag is way too thin to make microwave filters and other distributed element filters effectively and FR4 and FR408 is just to lossy.
One proposed topology is to transvert everything from the low frequency to the high frequency stuff up to X band or higher then mix it back down. This is because of the cost and size of components at 6GHz frequency range. distributed element circuits are cheaper, lower loss, and at higher frequency smaller. It is much cheaper to get high quality LO's at these frequency than lower frequency.
Given the desired size of the radio I am stuck using BGA's in the complete device.
Yeah that is kind of a big deal the difference in performance gap. How did that happen, someone in marketing order a engineer from another product line or something? that makes no sense.
I know ARM M4's are very very good at doing filtering, maybe one of the better architectures in this range. That said I agree about the learning curve as to get the most you either pay a arm and and a leg for libraries and compilers or write what you need to be fast in assembly. I still am amazed that none of the vendors have added support for things like a FIR optimized pipeline that does not require the CPU.
 I am cheap and going to try and make this project open source so assembly for me it looks like.
Someone PLEASE FIND ME A CHIP FPGA OR CHIP with ADC's, DAC's, and USB so I don't have to program in assembly. I have payed my dues already to the assembly god's and thought I was done.
Offline nctnico
« Reply #22 on: April 06, 2015, 11:36:53 pm »
AFAIK NXP or ARM offer extensive DSP libraries so no need for assembly programming.
Offline tggzzz
« Reply #23 on: April 06, 2015, 11:45:17 pm »
Firstly I don't see what the level of silicon integration has to do with your choice of programming language.
Secondly, you do realise that there would be a lot of digital noise coupled into the analogue circuits. It is difficult enough to sort that out at the board level, and much more difficult inside a single chip.
Finally, you do realise that, for high performance analogue, the analogue and digital transistors are based on very different processes.
(And the Red Pitaya has significant analogue outputs; some people are using it as a sig gen + scope => network analyser.)
« Reply #24 on: April 07, 2015, 03:16:56 am »
Good to here!
You are right very much right but. If there is no support for optimized DSP and other optimized functions these would almost certainly require some hand optimizations ie assembly. I know I am not the most articulate person and here it has shown thou here.
Yes I very much do, It comes but to what I am trying to. I am not making the next greatest spectrum analyzer, VSA, VSG, or VNA. I am trying to make a cost effective tool for student labs. This way the students can buy there own hardware and do the labs at home or ... . This is why I am trying to keep the cost down to the very very minimum while still having some performance*. If there was a RTL-SDR that was also a transmitter and could extend into the 6GHz range. This way students could have some hands on expense with channels that are more then 1 or 2 lambda and have a lot of multi-path.
I am a little confused why you are recommending the Red Pitaya. Seem like a great product and I have been interested in getting my hands on one for some time now for personal use. It does not any of the things that I need for undergraduate and graduate communications classes. It seems to have a -3dB point of just 50MHz. This is more then enough for a lot of applications but not this one. Also it fails to meet the price spec. Students can not by 2 $450 devices. That is like the price of one new text book nowadays  ;).
When you need a VNA you need a VNA and most likely a lot of performance from it. This is why I have a few of these at work and not just a couple of scopes and signal generators.
http://www.keysight.com/en/pd-1654293-pn-N5245A/pna-x-microwave-network-analyzer?
Its all about hte right tool for the job.
