hello i wonder if any STM engineers can see what's wrong with my code. it's an STM32F030F4P6 chip. all it does is blink an LED. the problem is i set the system clock as HSI/2 * PLL multiplier. so it's supposed to be 8MHz/2 * 12 = 48MHz. so the macro RCC_CFGR_PLLMUL12 determines the PLL multiplier. but when i change the 12 to a 2 as in RCC_CFGR_PLLMUL2 the LED frequency does not change. the system clock frequency is the same with 2 as it is with 12.
#include "stm32f030x4.h"
int main(void)
// sysclock configuration
RCC->CR |= RCC_CR_HSION;
RCC->CR |= RCC_CR_PLLON;
RCC->CFGR &= ~RCC_CFGR_PLLSRC;
RCC->CFGR |= RCC_CFGR_PLLSRC_HSI_DIV2;
RCC->CFGR &= ~RCC_CFGR_PLLMUL;
RCC->CFGR |= RCC_CFGR_PLLMUL12; // <----- changing the multiplier has no effect
RCC->CFGR &= ~RCC_CFGR_SW;
RCC->CFGR |= RCC_CFGR_SW_PLL; // PLL on
RCC->CFGR &= ~RCC_CFGR_HPRE;
RCC->CFGR |= RCC_CFGR_HPRE_DIV1; // sysclk (ahb) not divided
RCC->CFGR &= ~RCC_CFGR_PPRE;
RCC->CFGR &= RCC_CFGR_PPRE_DIV1; // apbclk not divided
RCC->AHBENR |= RCC_AHBENR_GPIOAEN;
// GPIO pin configuration
pinpos = 4;
GPIOA->OSPEEDR &= ~(GPIO_OSPEEDR_OSPEEDR0 << (pinpos * 2));
GPIOA->OSPEEDR |= ((uint32_t)(0x03) << (pinpos * 2)); // high speed 50MHz
GPIOA->OTYPER &= ~((GPIO_OTYPER_OT_0) << ((uint16_t)pinpos));
GPIOA->OTYPER |= (uint16_t)(((uint16_t)0x00) << ((uint16_t)pinpos)); // type push/pull
GPIOA->MODER &= ~(GPIO_MODER_MODER0 << (pinpos * 2));
GPIOA->MODER |= (((uint32_t)0x01) << (pinpos * 2)); // mode = output
GPIOA->PUPDR &= ~(GPIO_PUPDR_PUPDR0 << ((uint16_t)pinpos * 2));
GPIOA->PUPDR |= (((uint32_t)0x00) << (pinpos * 2)); // no pull
while(1){
GPIOA->ODR ^= (1 << 4); // toggle LED
for (y = 0; y<500; y++){ // delay about 1 second
for (x = 0; x<500; x++){}
