Author Topic: wch openocd liberated from proprietary driver  (Read 9737 times)
Offline jnk0leTopic starter
« on: February 19, 2024, 12:07:58 am »
openocd fork for wch is finally liberated from proprietary driver.
Only requirement is to install winusb (libusb) by zadig tool. (uninstall proprietary one first)
All that was needed was this:
https://github.com/jnk0le/openocd-wch/commit/aa6b548f74dbfba2f240660fcc70ed70f12a1ca9
Literally.
ch347 (aka ch342 aka ch345 aka ch341) based adapters couldn't be liberated due to missing some files.
prebuild packages are available here: https://github.com/jnk0le/openocd-wch/releases/tag/28012024-liberated
« Last Edit: March 10, 2024, 01:46:35 pm by jnk0le »
Offline prosper
Re: wch openocd liberated from proprietary driver (WCH-LinkE only)
« Reply #1 on: February 21, 2024, 02:44:00 am »
so, this consists of a flash driver for the various wch mcus, a transport driver for the single wire debug interface, and a driver for tge various wchlink programmers?
at a glance, it seems to support riscv and arm mcus, but not the 8051s. Which wchlinks does it support? (wait, i see, the linkE only)
is this going to be upstreamed, or is the plan to maintain it as a fork?
very exciting. thanks for your work on this!
« Reply #2 on: February 24, 2024, 03:01:55 pm »
Should support all, but the button-less one still needs proprietary driver.
It's basically generic openocd with added support for WCH stuff.
The code is spaghetti enough to not get upstreamed, not to mention the way it's being developed (https://github.com/jnk0le/openocd-wch/pull/1#issuecomment-1738259661) and merged back into the tree
« Last Edit: February 25, 2024, 11:45:12 pm by jnk0le »
« Reply #3 on: February 26, 2024, 12:32:21 am »
Wait, button less one is CH549 (aka ch375 of course). Should be liberated as well.
ch347 is the HS jtag flashed onto WCH-LinkE (or a dedicated chip with jtag)
« Last Edit: February 26, 2024, 12:43:05 am by jnk0le »
