Do you have a reference for that?
I watched all of his lectures, and that statement is based purely on my understanding of the architecture. It is possible, of course, that they have thought this through, but I feel like they really did not and interrupts will be implemented as a hack with a separate belt, which will mean very inefficient communication between the main belt and interrupt belt.
I apologize for the very, very late response, but I thought that a bit of thread necromancy was called for, as I don't know if you ever found the answer to this matter.
Note that I am myself still unsure if the Mill is ever going to be a working system, or if will even come close to the promoted performance if it does (probably not), but frankly (as Godard says himself many times) these things are only the bare minimum of a successful product in any case. Circumstance, happenstance, and marketing are far more important no matter what, for any product.
That having been said, you are correct in that it would use a second belt for interrupts, as is explained in the second of Godard's lectures. Indeed, this is the case for
any procedure call - and in the Mill design, an interrupt is simply a procedure call initiated externally.
However, this is a misleading answer, and the way it is misleading is directly related to the question you raise. The question presupposes that the belt is a single fixed sequence of registers treated as a FIFO queue - which is the way it seems to the programming model, but is not, in fact, the way it is implemented in any of the planned designs.
Note that I said 'design
s'. Godard makes this point repeatedly in the videos, that planned Mill CPUs would be a family, not in the sense that the x86 is, with a single binary execution model and a single basic hardware implementation (which might change over time, but would be the same for a given generation), but a family in the sense that the System 360 was - a single
programming model, and a (mostly) common assembly language for compilers to target, but with different concrete instruction sets (they intend to use the same kind if 'assembly specializer' IBM used, in fact) and hardware implementations that could be radically different.
He gives one example approach to implementing the belt, one which he says is one they do mean to use in some models but which would not be universal. The layout he described is a large anonymous register file and a pointer to the current head of the belt; the belt would be operated on as a ring buffer. As elements are added to the belt, the belt head (which is entirely inaccessible to the program, being part of the CPU's internal state) would advance, and the results would be added to the top of the belt while the bottom of the belt is cleared (to prevent insecure peeking, though that really shouldn't be possible anyway unless there is a flaw in the hardware - there is no way to access the parts of the belt register file outside of the section currently in use by the belt).
There is a separate, sequestered stack for procedure return addresses. Procedure arguments are to be placed onto the belt; any values that still need to be kept by the function but would go off of the belt would be explicitly spilled to a scratchpad area (which is the case for data that would fall off the belt before it is 'dead' in general, not something specific to procedures). If a nested procedure (assuming that you are using them, which in turn means it depends on your using a language which supports nested procedures with lexical scope) needs to use a value in the caller's scope, it is up to the compiler to keep track of where it is on the belt (or in the scratchpad).
When a procedure call occurs, the belt head is advanced one 'belt length' past the current procedure's belt. When the procedure exits - well, I am not entirely sure if I've got this right, but my understanding is that the compiler is meant to arrange the return values so that they are at the end of the belt, and the previous procedure's values are then copied to the remainder of the belt in hardware (and the residual values in the previous belt cleared) as part of the return op. The important thing here is that the return values are spliced to the values at the top of the caller's belt.
A later video talks about how the sequencing of execution is used in this to chain successive calls, and thus provide hardware tail call optimization, but that's another issue entirely. Presumably, in this design, if the call depth exceeds the belt register file and wraps, the overwritten part would be invisibly spilled to the scratchpad or something similar.
Interrupts are essentially just procedure calls in this model. When the interrupt occurs, the interrupt routine is looked up in a vector table as usual; however, I get the impression from the talks and the Mill Computing wiki that the vector table is yet another sequestered register file like the return address stack and the parts of the belt register file not currently in use, and that setting a vector requires a specific instruction. Since a hard interrupt wouldn't have a return value (I get the impression that there are no soft interrupts, and even if there are, they would again behave like a regular procedure), the merge step can be skipped, but this would be true of a void procedure anyway.
Now, I don't know enough about how this would actually perform, so I can't speak to its plausibility as a working model, but that should at least answer the question according to the available information.
