Author Topic: MS51FB9AE  (Read 2540 times)
Offline 1230
  • Country: in
MS51FB9AE
« on: March 25, 2021, 11:29:45 am »
Hi all,
pls share whats the syntax in keil for pin read?
and also if someone has some example for this controller, pls do share except that of BSP ones.
Thank you :) :-+
Offline crossroad
  • Avian World Theory
Re: MS51FB9AE
« Reply #1 on: March 26, 2021, 02:43:42 am »
I've never worked with nuvoton chips but it should have memory mapped peripherals.
If you're not using any abstraction layer, you have to read from a specific register.
With CMSIS and STM32 chips, it can look like
variable = GPIOA->IDRThis stores the pin values of all GPIO pins to "variable" and the bit position corresponds to the respective pins
This document should have everything you need for most things you want to do with that chip, if the manufacturer did their job
https://www.nuvoton.com/export/resource-files/TRM_MS51FB9AE_MS51XB9AE_MS51XB9BE_EN_Rev1.03.pdf
Offline PCB.Wiz
Re: MS51FB9AE
« Reply #2 on: March 26, 2021, 03:22:41 am »
Hi all,
MS51 is an 8051 cored part, so any of the keil docs for the 8051 are applicable.
One example is
8051 Bit I/O Example Program
https://www.keil.com/download/docs/84.asp
Offline PCB.Wiz
Re: MS51FB9AE
« Reply #3 on: March 26, 2021, 03:24:04 am »
 The MS51 is an 8051 part, and that has direct boolean opcodes and boolean pin access.
