Author Topic: Cube IDE + 32F4: is there any limitation on debugging "overlays"  (Read 1673 times)
Offline peter-hTopic starter
In general a project writes the FLASH starting at the base i.e. 0x8000000.
I have an "overlay" scheme where the base 32k remains (the "boot block") and the overlays start at 0x8008000.
I found that Cube does correctly program the FLASH from 0x8008000. Actually I have a separate Cube build (in a VM) for the overlays. So it seems that the Cube+SWD debugger system does not just erase the whole CPU. But how does it do it? It so happens that the bottom 32k is a separately eraseable block on the 32F417 (which, no surprise, is why I chose a 32k block for the boot block) but what if you wrote the linkfile with a starting address of base+4k? Cube would have to read the block first, and merge the data, before programming.
A second question is what happens when you try to single step through the overlay. Obviously, if you build the boot block and the overlay in one Cube project (various threads in years past, with people telling me I am stupid, and boot blocks should always be separate projects) then Cube has access to all the symbols and it all works. But what if you build the overlay in a separate Cube installation? That works too in as much the overlay runs ok, but you can't debug it.
Now, the running Cube does not have access to the symbols used to build the overlay. It's an interesting problem. For it to work, all the addresses relating to the overlay (text, data, bss, common, etc) must be identical. This is achievable but turns out to be very hard. I struggle to see why, because the GCC tool set seems to generate the output in a varying order. I am sure there is no guarantee on the order,  so lots of people will say I am stupid, again. But why is the order different between two builds? One with a base of 0x8008000 and nothing below that, and one with a base of 0x8000000, some code in there, then a gap, and then code starting at 0x8008000. In those two cases the ordering of stuff is not the same from 0x8008000 onwards.
What happens is subtle. Single stepping works starting from 0x8008000 but after maybe 100 lines the next step lands in hyperspace. It seems to happen not with my own code but when calling a stdlib etc function like memcpy. The locations of such functions are determined by the linker, but in some random way.
It should be possible to get data and bss in the same order but even that is elusive; if you have say
uint32_t fred1;
uint32_t fred2;
the linker can just place fred2 before fred1. Usually it doesn't but sometimes it just does it. Then due to the effect of various align 4 directives in the linkfile, the addresses all change from some point on.
If I was writing these tools I would never do something which gratuitously reorders stuff.
Anyway, it may be possible to transfer a symbol table from the Cube used to build the overlay to the Cube used to build the boot block or used to build the whole project. Then you could step through the boot block and continue stepping through the overlay (and set breakpoints etc). Is there any way to do that? It would have to override existing symbols of same name.
« Last Edit: July 01, 2023, 02:28:00 pm by peter-h »
Offline hussamaldean
  • Country: iq
Re: Cube IDE + 32F4: is there any limitation on debugging "overlays"
« Reply #1 on: July 01, 2023, 06:34:59 pm »
modify the linker script to have two application.
First one from 0x0800 0000.
The second one the desired address.
Offline ejeffrey
« Reply #2 on: July 03, 2023, 07:10:32 pm »
The way I do this is to create a bootloader project that only affects the bootblock, then a main project that has separate memory regions for the bootblock and the main program.  The "boot block" in the main application simply contains an assembly stub that jumps to the main programs entry point.
When I run the main program from the debugger it overwrites the bootloader with the stub and it works just fine with no bootloader.  This means that I can still flash from the IDE and  debug on a new or completely erased chip.
It's not the only way to approach it but it works well for me and it's never caused a problem like you describe.
Offline ejeffrey
« Reply #3 on: July 03, 2023, 07:35:29 pm »
I'm not sure what you mean here, or why having a matching order of symbols would be needed.  If the boot block and overlay are truly completely independent then it shouldn't matter.
In terms of the toolchain, I don't think either gcc or gnu ld really reorder things.  Gcc will generate output symbols for each input symbol in the source code order.  The linker will process the sections in the order of the link script, putting each input section in the requested output section as the come up.  But it's subject to enough weirdness from the order reference resolution, things like gc-sections and collapsing weak symbols that I wouldn't rely on any particular order of symbols and if I wanted to enforce ordering I would do that with special purpose sections.
If the second example has symbols in the boot block that replace ones from the overlay that could have ripple effects on the whole overlay.
« Reply #4 on: July 03, 2023, 10:10:30 pm »
They are independent in execution (the overlay has an entry point at base+32k and no parameter passing) but for Cube to be able to step through the boot block and then continue seamlessly to step through the overlay, it needs to have the symbols for both.
I also do what I think you do which is to debug a single block, and that obviously works fine.
Yes I think this is just too hard.
Offline Nominal Animal
« Reply #5 on: July 04, 2023, 12:20:18 am »
GDB has full overlay support when operating on the target ELF file.
Basically, use manual overlay control,
    overlay manual
Then, when you know a specific overlay has been mapped (copied from storage to runtime location), tell GDB about it using
    overlay map name
and when it no longer mapped (has been overwritten or another mapping is active), unmap it using
    overlay unmap name
To list the currently mapped overlays, use
    overlay list
Automatic overlay debugging support requires that your code exports symbols _novlys, _ovly_table, and _ovly_debug_event(), and the code that manages the copying/clearing of overlays will maintain the contents of _ovly_table (mapped fields) and then call _ovly_debug_event() (which the code also defines as an empty function).  Then it suffices that you tell GDB overlay auto, and GDB will set a breakpoint at the _ovly_debug_event() to reread the _ovly_table array, to determine which overlay is mapped.  Even breakpoints in code in overlays will then work.
