Author Topic: CH32V307V-EVT-R1 - DAC for scart signal  (Read 372 times)
Offline blalloTopic starter
« on: March 17, 2026, 09:45:58 am »
Hello everyone!
I'm trying to output RGBs from the CH32V307V-EVT-R1 board.
I'm using a r-2r ladder to output RGB888 (R: 270ohm, R2: 560ohm) and it looks decent on the oscilloscope.
The problem is sync: without the scart load, the signal looks perfect (even has frequency of 15.6khz), i put a 330ohm resistor in series since the signal is 3.3vpp, but when i attach it to the scart it gets very noisy (and sync doesn't hold).
Do you have any hints? Thanks!
Offline fchk
Re: CH32V307V-EVT-R1 - DAC for scart signal
« Reply #1 on: March 17, 2026, 12:52:29 pm »
Try an OpAmp as buffer. Video signals are usually terminated with 75 Ohm, and the source needs to deliver the current.
« Reply #2 on: March 17, 2026, 01:08:11 pm »
Do you have any suggestion for a good suited opamp for the purpose?
Online HwAoRrDk
« Reply #3 on: March 17, 2026, 04:45:21 pm »
Texas Instruments THS7316 is pretty popular for buffering RGB video.
