Author Topic: Modern day M68K development  (Read 622 times)
Online Gribo
« on: April 15, 2021, 01:35:57 pm »
Hello all,
 I got a task to develop test firmware for a board with a 68332 MCU, I have the PEmicro Multilink FX adapter, and would like to setup a toolchain. Sadly, Codesourcery lite is no longer available.
What are my options? I am using windows 10.
I am available for freelance work.
Offline SiliconWizard
Re: Modern day M68K development
« Reply #2 on: April 15, 2021, 03:57:38 pm »
I have used the toolchain provided here: https://gnutoolchains.com/m68k-elf/
and it works fine.
Online Gribo
« Reply #3 on: April 16, 2021, 01:12:40 pm »
Thanks for the info.
I have installed the toolchain, and got Eclipse to create a project with all the headers, now it seems I am missing some resources.
I installed version 4.8 of the toolchain.
Offline Harjit
« Reply #4 on: April 17, 2021, 03:32:59 pm »
There is some good information here: https://wiki.control.fel.cvut.cz/nms/cpuarch/m68k/mo_cpu2-quick-start.html
Has anyone found an inexpensive USB BDM tool? This is for a hobby project.
Offline bingo600
« Reply #5 on: April 17, 2021, 05:47:19 pm »
Those are classic Newlib ... DIY routines , missing.
You have to implement them your self
/Bingo
Offline westfw
« Reply #6 on: April 18, 2021, 09:14:17 am »
newlib in its full form likes to have resources that aren't that applicable to a small embedded system.
Figure out how to use newlib-nano instead, and it should be happier!
Probably something like "--specs=nano.specs --specs=nosys.specs" in the link command (may also require that you re-build newlib...)
