Author Topic: AVR32UC3B Clock Setup  (Read 1115 times)
Offline Jacky_88
« on: June 11, 2017, 03:07:27 pm »
Hello,
i'm starting to use 32bit AVRs and I have a problems setting up the main clock.
int main(void)
AVR32_PM.MCCTRL.osc0en = 1;
AVR32_PM.OSCCTRL0.mode = 7;
AVR32_PM.OSCCTRL0.startup = 0;
while(!AVR32_PM.POSCSR.osc0rdy)
  AVR32_PM.PLL[0].pllcount = 16;
  AVR32_PM.PLL[0].pllmul = 9;
  AVR32_PM.PLL[0].plldiv = 1;
  AVR32_PM.PLL[0].pllopt = 3;
  AVR32_PM.PLL[0].pllosc = 0;
AVR32_PM.PLL[0].pllen = 1;
    while(!AVR32_PM.POSCSR.lock0)
AVR32_PM.MCCTRL.mcsel = 2;
AVR32_GPIO.port[0].gpers = (1 << 31);
AVR32_GPIO.port[0].oders = (1 << 31);
AVR32_GPIO.port[0].ovrs = (1 << 31);
    while (1)
AVR32_GPIO.port[0].ovrt = (1 << 31);
As far as chapter 9 says, these seetimgs result in a fVCO of 120 MHz (12MHz crystal) and a PLL frequency of 60 MHz. But the settings still don't work. The PLL lock flag never changes resulting in an endless loop  :-\
Offline ataradov
    • Personal site
Re: AVR32UC3B Clock Setup
« Reply #1 on: June 11, 2017, 09:14:18 pm »
Why? This is one bad move. Just use ARM, you will get better variety of parts and actual support.
Alex
Offline Jacky_88
« Reply #2 on: June 11, 2017, 09:46:49 pm »
That is due to the availability of ARM from Atmel in germany. German stores don't offer them (as far as I know) and so I decided to start with the UC3B which is available here. The STM32-F1-series is also available here, which looks interesiting to me too. It would come at lower price for controllers and programmer (Dragon / ICE vs. ST Link V2), but has a huge downside with it's not existing IDE. I've already lying a NUCLEO on my desk.  Actually I'm very happy with Atmel and it's visual studio clone and depending on my experience with the AVR32 I would consider buying the ARMs from digikey.com in the future. As a hobbyist I have to consider the shipping fees, when ordering chips from digikey, farnell or mouser or have to purchase beyond some limit to get free shipping. But you're right, these SAMD look very nice  :D
« Last Edit: June 12, 2017, 07:16:15 am by Jacky_88 »
Offline Jacky_88
« Reply #3 on: June 23, 2017, 07:49:14 pm »
The code works. Since I'm, using a simple QFP adapter I had to wire it all manually and I conected the PLL supply to the wrong voltage line.  |O
« Last Edit: June 23, 2017, 07:55:24 pm by Jacky_88 »
