When writing Microchip PIC Assembly, I often use the "high" and "low" preprocessor directives to facilitate entering integers, for example in decimal radix:
movlw high(1234)
MPLab 8.92 accepts: low, high, and upper for three-byte integers. I suspect there are no such operators for 4-bytes and more. However, is there a convention for naming the bytes of 4-byte numbers, for example something like low, high, upper, and ****?
Regards, John
