Author Topic: MPLAB ICD 4 is EOL!  (Read 8068 times)
Offline ZuccaTopic starter
  • EE meid in Itali
MPLAB ICD 4 is EOL!
« on: January 25, 2023, 04:05:09 am »
Probably already known for most of you, but to me it was a suprise...
https://www.microchip.com/en-us/development-tool/dv164045
Product is End of Life (EOL), please consider MPLAB® PICkit™ 4 or MPLAB ICE 4 for your design needs.
Probably the business case for the ICD 4 was deep red... and they are now trying to get some traction on the new ICE4....
Can't love what you don't
Offline bentyler
  • engineer, embedded enthusiast
Re: MPLAB ICD 4 is EOL!
« Reply #1 on: January 25, 2023, 05:09:43 am »
The price of the ICE4 is $1800.. What a throwback to the good old days lol.
Offline BradC
« Reply #2 on: January 25, 2023, 05:12:43 am »
At least the Pickit 4 is still current.
Offline JPortici
« Reply #3 on: January 25, 2023, 05:21:35 am »
https://www.microchip.com/forums/FindPost/1218954 :(
ICD4 used Spartan 6
AMD/Xilinx EOL'd with no last time buy possibility
Online SiliconWizard
« Reply #4 on: January 25, 2023, 05:46:21 am »
Crazy. So now it's either an expensive professional tool or crap for hobbyists. Nice move. Well maybe the Pickit 4 is not that crappy? But previous versions certainly were. I stil have an ICD 3.
I don't regret having switched to other vendors, with that and their software tools and compilers. Even if some of their products were good.
Offline JPortici
« Reply #5 on: January 25, 2023, 07:13:48 am »
It's not. I've not touched the ICD3 since MPLABX 5.50
The only PITA is that we have to use the IPE instead of the standalone to program one offs, but that may change soon, since someone took the time to reverse engineer the protocol.
https://www.microchip.com/forums/m1221852.aspx
and now a certain someone has to find the motivation to learn python and rewrite the script into a nice Qt application
Offline Karel
« Reply #6 on: January 25, 2023, 07:45:13 am »
There's also the "Snap": https://www.microchip.com/en-us/development-tool/PG164100
But indeed, it's a pitty the ICD 4 is EOL. Fortunately for us,  we use STM32 for new projects.
  • EE meid in Itali
« Reply #7 on: January 25, 2023, 03:16:14 pm »
Are there any µC supported by ICD 4 but not by Pickit 4?
Yes we are losing  with the ICD 4 the advance triggering and the high current to target.... but I think we can all survive without those...
  • EE meid in Itali
« Reply #8 on: January 25, 2023, 03:18:26 pm »
and what debugger?
Offline Karel
« Reply #9 on: January 25, 2023, 04:03:10 pm »
and what debugger?
For programming only we use ST-LINK/V2, for debugging we use a serial port and/or some gpio pins.
Offline JPortici
« Reply #10 on: January 25, 2023, 04:12:32 pm »
I don't use ancient devices, nor devices that have just come out, but usually support for new devices is added at the same time in all fourth gen tools (and i see no reason why it shouldn't be this way)
curious: what do you get from the advance triggering that you can't do with the regular/data breakpoints?
  • EE meid in Itali
« Reply #11 on: January 25, 2023, 07:59:04 pm »
Oh mamma! Believe me between me and you surely you are the expert here.
I was hoping you would have an answer to the very same above million dollar question.
I can only assume if your firmware is done in a clean way you should never need any esoteric obscure advanced triggering.
Do you believe MC will continue to add support for new devices in the ICD 4? I hope you are right!  :popcorn:
Offline JPortici
« Reply #12 on: January 25, 2023, 08:42:28 pm »
I'm genuinely asking, as i've never had the pleasure to use the ICD4 :) way out of budget.
I skimmed again through the manual but i didn't see anything that indicated more complex debugging over the pickit.
Guy from microchip said they will continue adding support, the only thing we can do is believe them, or not. Maybe they are already redesigning using a new FPGA, who knows.
I honestly don't know what the FPGA does in the first place, probably hardware acceleration of the debug interface ? One of the things they claim is debug at full speed, but i don't have serious problems in debugging a dsPIC33C at full speed (100MIPS) with the pickit.
AFAIU the SNAP, PK4, PKOB4 and ICD4 all use the same firmware as a basis, as all use the ATSAM E51
  • EE meid in Itali
« Reply #13 on: January 26, 2023, 01:23:34 am »
Well I don't know either... I never had a ICD 4 as well... but I was looking for a cheap one used since years...
Offline IDEngineer
« Reply #14 on: January 26, 2023, 07:35:02 am »
This massively sucks. I've avoided the whole ICD4 phase, sticking with the trustworthy ICD3 and even buying a backup unit just in case. Now it appears I'll be two full generations behind. Doubt there will be many updates in the future.
Every single board we have in production uses the Tag-Connect ultra small footprint connector and cable. I don't even know if they have a compatible cable for the $1800 unit.
I seriously hate being orphaned by companies. We buy 10K+ PIC's annually. Might be revisiting that choice as we update our boards.
Offline Karel
« Reply #15 on: January 26, 2023, 07:37:38 am »
The reason for me to buy the icd 3 was only because the pk2 is slow when programming pic32.
But the icd 3 & 4 are still slow compared to an st-link/v2 & stm32.
Microchip's gcc is also slower than arm's gcc compiler.
Microchip tools, despite their fancy looks, are becoming dinosaurs.
When I'm developing and debugging firmware, the speed of the tools matters a lot.
Offline IDEngineer
« Reply #16 on: January 26, 2023, 07:55:10 am »
My workflow must be weird. I hear people say that the compile speeds and download speeds are a huge factor, but honestly I don't experience that. From the time I click the "reflash" icon until I turn my chair 90 degrees and pick up a scope probe, the code is flashed and running.
What matters to ME is having a bunch of production designs whose debugging connectors aren't supported. Guess I'll have to look at the PICkit4... though I was always led to believe that the little PICkits were substandard compared to their ICD big brothers.
  • EE meid in Itali
« Reply #17 on: January 26, 2023, 02:23:13 pm »
I feel your pain IDEng...
If something goes wrong in the future you are probably responsible to deliver solutions, and the excuse of tools EOL of whatever is something that could not be accepted.
You designed it, you will fix it. Maybe it's a good situation to get the ICE4 approved by management.
I don't have my designs in production, but  in the current situation I am forced to buy a Pikit4 [PK4] and see it's a good boy or not for my stuff.... I will be surprised if it is not the case, the general feedback about the PK4 is quite good.
Sensible also the suggestion from Karel going STM32, but I recall it was heavily impacted by the "chipageddon" shortage shit show.
Offline JPortici
« Reply #18 on: January 26, 2023, 04:07:44 pm »
In case you need help with the PK4, and it involves PIC devices, feel free to PM me. (PIC only because i currently don't use ATSAM parts so i can't provide any insight)
Though usually the solution is to update things: Monday there was an update under the hood that blocked the 4th gen tools - don't get me started i am extremely pissed off that things happen and are updated without your control - but luckily the IDE gave an helpful message that hinted you had to update the tool packs and some device packs. And yet there are at least four threads on the microchip forum from users that willfully ignored the message because "i don't want to update what i don't need" except the IDE told you to do that and then you complain that things don't work anymore.
Are you in italy now? ISTR from your posts in the past that you lived/worked in munich?
Offline IDEngineer
« Reply #19 on: January 26, 2023, 05:26:57 pm »
usually the solution is to update things: Monday there was an update under the hood that blocked the 4th gen tools - don't get me started i am extremely pissed off that things happen and are updated without your control... users that willfully ignored the message because "i don't want to update what i don't need"
Have to say, I'm sympathetic to those "don't update what I don't need" feelings. Generally I don't update what isn't broken for my needs. Yes, I know bug fixes are cumulative and all that. But I've been burned far too many times by following the lemmings over the cliff, and blindly updating just because an update was available, only to find that the update itself caused new problems. I didn't have problems before, but after the update I do. Talk about frustration!!!
Yes, we're heavily into PIC's especially the PIC18 family. If the ICD# is unavailable, we must have something that has an available TAG-Connect cable. Sounds like that may force us back down into the PICkits. I'm not opposed to the PICkits, but as I said I was given the impression they are a step backwards from the ICD's. Just seems odd to be moving backward.
  • EE meid in Itali
« Reply #20 on: January 26, 2023, 05:30:14 pm »
Thanks Portici,
I will PM you in case I stumble in unsolvable PIC problems.
No I wish to be in Italy all the time, right now I am in USA, SC trying to become rich so I can then spend all my money in Italy where I will be retiring in 30 years.
I was in Munich 15 years, but they offered me a job in USA I could not refuse....
« Reply #21 on: January 26, 2023, 06:45:32 pm »
Same here, good thing I'm not designing anything new with Microchip MCUs, and the ICD3 is fine for the occasional maintenance of older projects.
Offline JPortici
« Reply #22 on: January 26, 2023, 07:10:28 pm »
Thanks Portici,
you wouldn't need to do that if you didn't live in the most expensive city of continental europe and one of the most expensive in the US  ;D ;D ;D
ah, it was just so i could send you a contact for a local distributor that does miracles, local area only i'm afraid
Offline IDEngineer
« Reply #23 on: January 26, 2023, 11:27:09 pm »
I've just remembered that Microchip historically recommends AGAINST using PICkits for production programming. If ICD's aren't available, that pushes us into RealICE's... except I don't see a TAG-Connect cable for those.
I've reached out to TAG-Connect to ask their advice. But I cannot believe Microchip would orphan people like this.
Offline tumbleweed
« Reply #24 on: January 26, 2023, 11:56:35 pm »
You should be able to use an AC164110 RJ-11 to ICSP Adapter to connect a Pickit4 to a TagConnect cable.
I think the recommendation for not using the pickits as production programmers was simply because they don't verify at high/low VDD voltages.
Other than that there's not really much difference.
RealICE's are EOL too, so currently it's ICE4 or pickit4.
