Yes it looks like a graphics display.
Anyway, there are literally myriads of such displays on the market, with different characteristics and different controllers, so unless you're ready to re-write the code for the display, all bets are pretty much off unless you can find the exact same couple (display + controller). Even if it's the same controller but not the same display, it may not function as there can be a specific configuration (that again would require modifying the software.)
