Author Topic: MPLAB X Project Properties  (Read 222 times)
Offline L_Euler
« on: October 03, 2019, 12:10:00 am »
In MPLAB X under the General tab in Project Properties there is an option to change encoding with dozens of options.  Why and when would I make a selection in that field.  The user manual was not much help.
There's no point to getting old if you don't have stories.
Offline mpgmike
Re: MPLAB X Project Properties
« Reply #1 on: October 07, 2019, 07:54:44 am »
That has to do with how the compiler deals with the structure of your code.  When you choose your compiler (XC8 v2.10 for example), the appropriate ISO- format is assigned automatically.  With the release of MPLABX v5.0 the C based XCx went from C89 to C99 format.  You can choose C90 to use older code (or stay with familiar formatting style), which then will change the ISO- format.  Hope this helps.
