Author Topic: MPLAB X v6.10 fails with MCP2221(A) attached to computer  (Read 2345 times)
Offline jc101Topic starter
« on: June 07, 2023, 05:49:25 pm »
Having a new and shiny ICD 5 arrive, I thought I'd install MPLAB X 6.10 to give things a whirl.  All went well, until I plugged a box of mine in development and MPLAB X just quit.  Then it simply wouldn't start, nor would v6.05.  Though v6 did seem to launch OK.
It turns out, confirmed by Microchip support, that installing v6.10 isn't compatible with anything using a MCP2221(a) attached to the computer at the same time.  A fix is in the pipeline, though they wouldn't give a timeline.
This was their reply to my support ticket...
This is a known problem in version 6.10 and our developing team is working on it in order to release a new patch as soon as possible.
At the moment we do not have a specific date or estimate for the release of the patch.
The only workaround at the moment is to use an older version of MPLAB
To be more precise, it crashes with anything connected using the USB VID / PID  0x04D8 / 0x00DD, which also includes a number of Microchip dev boards.  Just a heads up for people.
Online SiliconWizard
Re: MPLAB X v6.10 fails with MCP2221(A) attached to computer
« Reply #1 on: June 07, 2023, 07:40:40 pm »
Sounds nice.
Offline woofy
    • Woofys Place
« Reply #2 on: June 07, 2023, 09:36:42 pm »
yeah, I also had stability issues with 6.10. reverted to 5.50 and all is well again.
6.00 is ok under win10, but crashes with linux (mint 20.3).
Offline JPortici
« Reply #3 on: June 08, 2023, 04:57:44 am »
yeeeeah :( we know
luckily apart from 5th gen tools support, there was nothing else that made it worth updating. 6.05 working good here
Offline jipihorn
    • jipihorn blog
« Reply #4 on: October 16, 2023, 07:55:21 am »
Hello,
Did Microchip correct this problem in the 6.15 version ?
Jerome
« Reply #5 on: October 16, 2023, 07:58:04 am »
Yes, you install 6.15, and then once it starts, there are some small patches to load.  Check the small speech bubble icon bottom right when it appears and install the updates it suggests.  It may take a few minutes for that to appear.
Offline jipihorn
    • jipihorn blog
« Reply #6 on: October 16, 2023, 10:25:49 am »
Ok, thank you.
The problem with microchip is that there absolutely no way to know easily if they corrected something. Their release notes are a useless mess and the rest is placed in a secret location.
Jerome
The following users thanked this post: Dazed_N_Confused
« Reply #7 on: October 16, 2023, 10:30:49 pm »
Well, in terms of hardware, to be fair, they do a decent job with erratas I think.
But in terms of software, that's a whole other story indeed.
Offline jipihorn
    • jipihorn blog
« Reply #8 on: October 17, 2023, 09:25:53 am »
I was speaking about software, of course  ;D
I do like the hardware, i don't remember having trouble with all the chips I used from them...
J.
