I'm using MPLABX IDE assembly debug to run through my code and have a few quick questions:
1. How do you display the programme steps, i.e. the total number for steps executed not the PC? My proprietary assembler shows this at all times.
2. Can you change the memory location for a variable with the name you've given it - (e.g. var_1 equ 0x20) to show "var_1" not "0x20".
3. This is a long shot: when using the ADC can you somehow "inject" test value into the debugger that will help in testing?
Thank you.
