Author Topic: MSPM0C microcontroller family VREF  (Read 371 times)
Offline IconicPCBTopic starter
« on: April 11, 2025, 03:49:28 am »
Trying to understand whether internal  VREF is accessible on the external VREF pin of the micro.
Would like to use the reference voltage elsewhere in the circuit.
Re: MSPM0C microcontroller family VREF
« Reply #1 on: April 11, 2025, 11:54:47 am »
Explicitly only the MSPM0G series bring the internal VREF to an external pin for the purpose of filtering/ decoupling the signal.
I can not comment on the MSPM0L or MSPS0C range of product.
Offline mikerj
« Reply #2 on: April 11, 2025, 11:59:52 am »
The MSPM0C devices don't even have a VREF in pin so the answer is no.  The G family parts have a pin tied to the internal Vref voltage, but it's intended for decoupling or driving an external Vref in rather than using it as a reference for external circuits, so it would likely need to be buffered in this case.  The L family parts have a Vref input only.
« Reply #3 on: April 11, 2025, 03:12:02 pm »
I have the C family1104 development kit, i shall see about the voltage present on external input pin when internal reference selected.\If internal ref present i intended to buffer it and use it in external circuit.
G family incorporates some op amps in which case expose internal V ref is no longer an issue.
