I'm trying to scale images with the display engine front end of the Allwinner F1C100s, but even though the status flags show the scaling process starts and finishes all that is presented in the write back memory is black pixels (0x00000000)
The datasheet and user manual are of no use apart from showing the available registers and what the bits in the settings mean, but no explanation of the operation of the scaler.
void scaler_load_settings(void)
int index;
//Show it is the scaler setup being done
display_set_fg_color(0x00FF4040);
display_set_font(&font_5);
display_text(50, 150, "SCALER SETUP");
//Enable the display engine front end
*CCU_BUS_CLK_GATE1 |= CCU_BCGR1_DEFE_EN;
//De-assert the display engine back end reset
*CCU_BUS_SOFT_RST1 |= CCU_BSRR1_DEFE_RST;
//Enable the DEFE clock in the CCU. (FE Clock Register)
*CCU_DEFE_CLK = 0x80000000;
//Enable the front end engine with cpu ram access enabled
*DEFE_EN_REG = DEFE_EN_ENABLE | DEFE_EN_BIST_EN;
//No color space conversion
*DEFE_BYPASS_REG = DEFE_BYPASS_CSC_BYPASS_EN | DEFE_BYPASS_DEFE_BYPASS_EN; //For test just skip the scaler
//Horizontal scaling only over a 4 pixel range
*DEFE_AGTH_SEL_REG = DEFE_AGTH_SEL_4_1;
//Only needed when interrupts are used
//*DEFE_LINT_CTRL_REG = 0;
//Set reading from the input buffer. Only channel 0 is being used.
*DEFE_BUF_ADDR0_REG = (uint32)input_buffer;
//*DEFE_BUF_ADDR1_REG = 0;
//*DEFE_BUF_ADDR2_REG = 0;
//No idea about this one
//*DEFE_FIELD_CTRL_REG = 0;
//Tiles are not used
//*DEFE_TB_OFF0_REG = 0;
//*DEFE_TB_OFF1_REG = 0;
//*DEFE_TB_OFF2_REG = 0;
//The input data has 1024 pixels per line
*DEFE_LINESTRD0_REG = 1024;
//*DEFE_LINESTRD1_REG = 0;
//*DEFE_LINESTRD2_REG = 0;
//Non tile based RGB888 (ARGB)
*DEFE_INPUT_FMT_REG = 0x00000051;
//Set writing to the output buffer
*DEFE_WB_ADDR_REG = (uint32)output_buffer;
//Non interlaced planer RGB888
*DEFE_OUTPUT_FMT_REG = 0;
//No interrupts
*DEFE_INT_EN_REG = 0;
//Clear all pending interrupts
*DEFE_INT_STATUS_REG = 0;
//No color space conversion used
// *DEFE_CSC_COEF00_REG = 0;
// *DEFE_CSC_COEF01_REG = 0;
// *DEFE_CSC_COEF02_REG = 0;
// *DEFE_CSC_COEF03_REG = 0;
// *DEFE_CSC_COEF10_REG = 0;
// *DEFE_CSC_COEF11_REG = 0;
// *DEFE_CSC_COEF12_REG = 0;
// *DEFE_CSC_COEF13_REG = 0;
// *DEFE_CSC_COEF20_REG = 0;
// *DEFE_CSC_COEF21_REG = 0;
// *DEFE_CSC_COEF22_REG = 0;
// *DEFE_CSC_COEF23_REG = 0;
//Input image is 1024 * 600
*DEFE_INSIZE_REG = (599 << 16) | 1023;
//The output image is 640 * 600
// *DEFE_OUTSIZE_REG = (599 << 16) | 639;
*DEFE_OUTSIZE_REG = (599 << 16) | 1023;
//1024 / 640 = 1.6, integer part is 1, fractional part based on 16 bits
// *DEFE_HORZFACT_REG = (1 << 16) | 39321;
*DEFE_HORZFACT_REG = (1 << 16);
*DEFE_VERTFACT_REG = (1 << 16);
//Enable CPU access to the coefficient memory
*DEFE_FRM_CTRL_REG |= DEFE_FRM_CTRL_COEF_ACCESS;
for(index=0;index<32;index++)
//All coefficients set to 1
DEFE_CH0_HORZCOEF_REGN[index] = 0x40404040;
DEFE_CH0_VERTCOEF_REGN[index] = 0x40404040;
// DEFE_CH1_HORZCOEF_REGN[index] = 0;
// DEFE_CH1_VERTCOEF_REGN[index] = 0;
//Disable CPU access to the coefficient memory
*DEFE_FRM_CTRL_REG &= ~DEFE_FRM_CTRL_COEF_ACCESS;
display_hex(500, 150, 8 , *DEFE_BUF_ADDR0_REG);
display_hex(500, 180, 8 , *DEFE_WB_ADDR_REG);
display_text(250, 150, "DONE");
int scaler_process_file(void)
uint32 result;
//Show the file processing started
display_text(50, 200, "FILE PROCESSING");
//Try to open the file for reading
result = f_open(&fp, "file_to_scale.bin", FA_READ);
//Check if file opened ok
if(result == FR_OK)
display_text(70, 230, "Input file opened");
//Read the settings into memory
result = f_read(&fp, (uint8 *)input_buffer, MAX_INPUT_SIZE * 4, 0);
//Done with the file so close it
f_close(&fp);
//Check if still ok to proceed
if(result == FR_OK)
display_text(70, 260, "Input file read");
if((*DEFE_STATUS_REG & DEFE_STATUS_WB_STATUS) == 0)
display_text(70, 290, "Scaler inactive");
//Allow scaler access to the memory
*DEFE_EN_REG &= ~DEFE_EN_BIST_EN;
//Start the scaling process
*DEFE_FRM_CTRL_REG |= DEFE_FRM_CTRL_FRAME_START | DEFE_FRM_CTRL_WB_EN | DEFE_FRM_CTRL_REG_RDY_EN;
if(*DEFE_STATUS_REG & DEFE_STATUS_WB_STATUS)
display_text(70, 320, "Scaler active");
//Wait for process to be finished
while(*DEFE_STATUS_REG & DEFE_STATUS_WB_STATUS);
display_text(70, 350, "Scaler done");
//Allow CPU to access memory
*DEFE_EN_REG |= DEFE_EN_BIST_EN;
result = f_open(&fp, "scaled_file.bin", FA_CREATE_ALWAYS | FA_WRITE);
if(result == FR_OK)
display_text(70, 380, "Output file opened");
result = f_write(&fp, (uint8 *)output_buffer, 1024 * 600 * 4, 0);
f_close(&fp);
if(result == FR_OK)
display_text(70, 410, "Output file written");
display_text(250, 200, "DONE");
return(1);
display_text(250, 200, "FAILED");
return(0);
I would appreciate if anyone that can shed some light on this reaches out.
