Ok, so I'm pretty confidant about this but a team mate has listed something different in our report and doubt has now crept in. I expect a bombardment of "OMG HOW CAN YOU NOT KNOW THAT" style comments but meh, if I get the one comment that provides the answer it's worth it right?
Anyway, when connecting a uC to some batteries and then a breadboard/pcb, am I right in saying that the negative terminal is effectively the ground. I.E. all the ground connections run back to there. NOT the GND terminal on the uC. This is connected TO the common ground but is not what actually grounds the circuit.
Need to fix this in the next hour so quick responses please!
Cheers guys!
