Author Topic: No output for NPWM generation on SAMD20 (No ASF)  (Read 1356 times)
Offline matthew_zammitTopic starter
  • Country: mt
« on: March 06, 2018, 08:05:57 pm »
Hi, I've been at this for quite some time now. I'm trying to generate a simple PWM using the NPWM wavegen mode but I get no output. I've tried using interrupts and it works fine but I need to use hardware generated PWM since CPU resources are crucial.
My suspicion is that the multiplexing pin configuration is wrong on my side. Below is the Timer initialization function.
//PB30 -- Tc0 Pwm output
void init_LED_Driver()
 //PWM INPUT PIN INIT
 REG_PORT_DIRSET1 = PORT_PB30;
 PORT->Group[1].PINCFG[15].reg  |= PORT_PINCFG_PMUXEN; //| PORT_PINCFG_DRVSTR  PERIPHERAL MULTIPLEXING FOR ADC_INPUT -- uncomment for increased o/p drive strength
 PORT->Group[1].PMUX[30].reg    |= PORT_PMUX_PMUXE_E; // ENABLE TC0/WO[0]
    Set the GENDIV.DIV TO DECIMAL 0
    and configure the settings to GCL3
 REG_GCLK_GENDIV  = GCLK_GENDIV_ID_GCLK3 | GCLK_GENDIV_DIV(0);
 while(GCLK->STATUS.bit.SYNCBUSY); // WAIT FOR SNCHRONIZATION OF CLKS AFTER RESET
    DIVIDE GCLK2 BY 2^(GENDIV.DIV+1)
    CLOCKED BY 32.768KHZ inTERNAL OSCILLATOR   -- ACCURACY NOT THAT IMPORTANT
    gclK O/P FREQ = 16.3KHZ
 REG_GCLK_GENCTRL = GCLK_GENCTRL_DIVSEL | GCLK_GENCTRL_GENEN | GCLK_GENCTRL_SRC_OSC32K | GCLK_GENCTRL_ID_GCLK3;
 // Configure Clocks
 REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN | GCLK_CLKCTRL_GEN_GCLK3 | GCLK_CLKCTRL_ID_TC0_TC1;
 REG_PM_APBCMASK |= PM_APBCMASK_TC0; // Enable TC0 APB clock BUS
 // Configure TC0 (8 bit counter by default)
 // Run in standby
 // Normal PWM generation
 REG_TC0_CTRLA |= TC_CTRLA_MODE_COUNT8 | TC_CTRLA_PRESCALER_DIV1 | TC_CTRLA_RUNSTDBY | TC_CTRLA_WAVEGEN_NPWM | TC_CTRLA_PRESCSYNC_GCLK;
 while(TC0->COUNT8.STATUS.bit.SYNCBUSY);          // Wait for sync
 // Get continUous read request from clock
 REG_TC0_READREQ |= TC_READREQ_RCONT | TC_READREQ_RREQ;
 //This register controls the period   -- 100HZ
 REG_TC0_COUNT8_PER = 164;
 //This register controls the duty cycle -- 50%
 REG_TC0_COUNT8_CC0 = 82;
 // Enable TC3
 REG_TC0_CTRLA |= TC_CTRLA_ENABLE;
 while (TC0->COUNT8.STATUS.bit.SYNCBUSY); // wait for TC0 to be enabled
Thanks in advance :)
Online ataradov
    • Personal site
Re: No output for NPWM generation on SAMD20 (No ASF)
« Reply #1 on: March 06, 2018, 08:41:06 pm »
TC0/WO[0] is on MUX F, not E.
Alex
  • Country: mt
« Reply #2 on: March 06, 2018, 09:04:36 pm »
Wow that was actually it. Weird that the datasheet from Atmel's website doesn't tell you this tho. Keil provides a more proof read datasheet for anyone using SAMD microcontrollers.
Online ataradov
    • Personal site
« Reply #3 on: March 06, 2018, 09:07:03 pm »
What do you mean it does not? How do you think I got this information? Columns for E and F are both allocated for TC, but they are clearly different.
Also, the latest datasheets are on Microchip site, I'm not sure what is published on Atmel site.
Alex
  • Country: mt
« Reply #4 on: March 06, 2018, 11:53:09 pm »
I've attached the two mentioned datasheets for the same alleged SAMD20
Online ataradov
    • Personal site
« Reply #5 on: March 06, 2018, 11:55:05 pm »
Well, they don't seem to update the atmel.com. Anyway, it is better to look for datasheets on microchip.com.
Alex
Online ajb
« Reply #6 on: March 07, 2018, 01:03:18 am »
The datasheet currently on Microchip's website is correct (and has already been updated to match Microchip's document style).  The one you have must be an old version.
