Author Topic: NodeMCU suddenly cannot connect to internet  (Read 1009 times)
Offline panossTopic starter
  • Country: gr
« on: June 25, 2018, 06:51:58 am »
My NodeMCU was, till yesterday, very easilly connecting to the internet.
Untill I installed a library, Thermistor_library-master.
From that moment the NodeMCU can no way connect to the internet!!!
I removed the library (deleted the library 's folder from C:\Users\Pan\Documents\Arduino), I tried previous sketches that worked 100% in the past, but NOTHING!
It cannot connect.
I even tried another (unused) NodeMCU and the same thing happens!
I 'm desperate, I don't know what to do!
Any help is welcome.
(I have made no changes to the router 's credentials or any of it 's settings)
« Last Edit: June 25, 2018, 08:13:44 am by panoss »
Offline Naguissa
    • Foro de electricidad, electrónica y DIY / HUM en español
Re: NodeMCU suddenly cannot connect to internet
« Reply #1 on: June 25, 2018, 12:11:36 pm »
Have you tried most simple solution? Restarting your WiFi/Router....
Sometimes routers, APs and so on goes nuts.....
It cannot connect.
  • Country: gr
« Reply #2 on: June 25, 2018, 02:05:08 pm »
Yes, I tried this.
Well the solution was that I replaced this code:
    WiFi.begin(ssid, password);
with this:
    WiFi.disconnect(true);
    WiFi.setAutoConnect(false);
    WiFi.setPhyMode(WIFI_PHY_MODE_11G);
    WiFi.printDiag(Serial);
    Serial.println(WiFi.getPhyMode());
and...got connected!!!
Then I removed the new code and replaced it with the old one:
and works fine too!!!
I have no idea why the use of the previous code 'cured' it!! :-//
The following users thanked this post: Naguissa
