Author Topic: Nokia5110 LCD (PCD8544 controller) with PIC18F4550  (Read 5031 times)
Offline BibiricatTopic starter
« on: March 25, 2014, 01:08:33 pm »
Hello.
I just bought a Nokia5110 LCD and i was trying to interface it with a pic18f4550, but i can't find any example code to use with C18 or Hytech C compilers, as most of the results are with arduino or old broken links.
Does anyone have some example code for PIC mcu's ? Any example code would do.
Offline dannyf
Re: Nokia5110 LCD (PCD8544 controller) with PIC18F4550
« Reply #1 on: March 25, 2014, 01:13:28 pm »
Don't find sample code. Find the datasheet for your lcd / chip and write code to drive it.
The following users thanked this post: Dom13c
Offline diyaudio
« Reply #2 on: March 25, 2014, 01:49:10 pm »
Hello.
@Danny is right find the datasheet  then get some coffee/tea and watch this while reading the datasheet.
Arduino Nokia 5110 LCD Tutorial #1 - Connecting and Initial Programming
Note ignore the Arduino title, you can port the code after understanding the abstract. I found this LCD more fun and easy than HD44780U controllers.
Note if you bought it off ebay, the video says it will work from 5V or 3.3V, but I had a different experience the batch I have seems to only work off 3.3V, I tested a batch of 5 pieces (with the blue back light).
« Last Edit: March 25, 2014, 01:50:52 pm by diyaudio »
Offline andyturk
« Reply #3 on: March 25, 2014, 03:19:25 pm »
Here's my attempt:
pdc8544.h
pdc8544.cc
It's C++, but may be useful anyway.
