Author Topic: NXP announce ARMs down to 8 pins and $0.39  (Read 16049 times)
    • Mike's Electric Stuff
Day Job: Mostly LEDs
Offline firewalker
  • Country: gr
Re: NXP announce ARMs down to 8 pins and $0.39
« Reply #1 on: November 13, 2012, 03:34:36 pm »
Nice.
Alexander.
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: November 13, 2012, 04:34:26 pm »
Cortex is the way to go. it's going tokill off most others.
Offline andersm
« Reply #3 on: November 13, 2012, 04:55:27 pm »
IIRC it took NXP about a year from announcement to actually releasing the commodity-packaged LPC1100 series, and most models still aren't in stock anywhere. Let's hope they're a bit better about getting the product out there this time around, because the chips really do look very interesting.
Offline TheDirty
« Reply #4 on: November 13, 2012, 05:25:11 pm »
Peripherals are all revamped and it comes with an internal oscillator.  Looks pretty good.  Really, the internal oscillator thing is what makes me use PICs or MSP430's rather than CM3's or CM0's in my day to day hobby designs.  Putting in a crystal is so inconvenient.
Mark Higgins
Offline mrflibble
« Reply #5 on: November 13, 2012, 05:26:01 pm »
Ooooh, neat. Preorder *clickie*
Offline TheDirty
« Reply #6 on: November 13, 2012, 05:40:15 pm »
I guess Microchips patents for multifunction pins has been revoked then.  I can't find anything on the results, but Microchip sued both Zilog and Luminary Micro (Now Texas Intruments) for a patent they have regarding low pin count microcontrollers and pins sharing GPIO and programming/debug functionality.
Mark Higgins
Offline nctnico
« Reply #7 on: November 13, 2012, 06:37:05 pm »
All Cortex M0 en M3 parts from NXP have a 1% accurate RC oscillator. Works like a charm.
Offline andersm
« Reply #8 on: November 13, 2012, 07:27:29 pm »
ST's parts also have internal RC oscillators with similar accuracy. TI's older parts have terrible 30% accurate oscillators, while their newer ones also have 1% accuracy.
Offline TheDirty
« Reply #9 on: November 13, 2012, 07:42:47 pm »
Right.  Don't know what I was thinking of there.  I've used a lpc11xx once without the crystal before for my datalogger.  Not certain why I figured they were needed again.
Mark Higgins
Offline brainwash
    • Hack Correlation
« Reply #10 on: November 13, 2012, 09:26:12 pm »
That's great news, more cheap powerful options to choose from.
Just my main gripes with these modules for using them in one-off projects:
- no native 5V or 5V tolerant operation
- no ADC, though it has a comparator
- probably no high-power pins, datasheet lists a nominal current of 3-4mA for I/O pins and 100mA absolute limit for the chip
I thought the whole reason of supplying low pin-count DIP packages was to get away with minimal external components while prototyping.
Offline Bloch
« Reply #11 on: November 13, 2012, 09:34:11 pm »
[size=78%]- no ADC, though it has a comparator[/size]
Yes if whey did try ? to compete with microchip. Then they will fail completely.
Thank you for the info. No need to waste my time on a new 8 pin brain  ;D
Offline bxs
« Reply #12 on: November 13, 2012, 10:23:50 pm »
Crazy, no ADC  :o
And probably will be very limited to direct interface external stuff (Voltage and amount of Current)
This will help, but far from killing 8Bit  ;D
Offline nctnico
« Reply #13 on: November 13, 2012, 10:26:44 pm »
Just wait until the final datasheets are on NXP's website. They are problably still designing the chips right now. When they announced the Cortex M3 devices the peripherals they promised are different from what ended up in the chips.
I also wonder why they don't use an SO-8 or MSOP-8 package. That would allow for a real tiny footprint.
« Last Edit: November 13, 2012, 10:29:07 pm by nctnico »
alm
  • Guest
« Reply #14 on: November 13, 2012, 11:12:31 pm »
According to the (preliminary) datasheet, all of the pins except /RESET and the VDDCMP pin are 5 V tolerant.
Offline brainwash
    • Hack Correlation
« Reply #15 on: November 14, 2012, 12:42:35 am »
Well, yes, for input pins, but not for supply voltage which has an absolute maximum of 4.6V. Not sure why they went 90% of the way and stopped there.
Even though the pins support 5V input, you can only get something slightly below Vcc output. It's a moot point anyway, the part was designed with 3V3 interfacing in mind and low currents.
alm
  • Guest
« Reply #16 on: November 14, 2012, 12:49:33 am »
I've never seen 5 V tolerant VDD pins. It either supports 5 V VDD or not. In the latter case, the inputs may still be designed to handle inputs up to 5 V, hence being 5 V tolerant. Designing protection structures so the pins work properly with 5 V input voltage is quite different from designing the core to work on 5 V, which would require a different (more expensive / lower density) process.
Offline nctnico
« Reply #17 on: November 14, 2012, 01:35:23 am »
Just forget about 5V. Its a relic from the 70's  O0 Nowadays many larger designs I work on use 1.8V as the primary digital supply voltage. Most mainstream parts will work on 3.3V so its actually easier to use 3.3V than 5V.
Offline brainwash
    • Hack Correlation
« Reply #18 on: November 14, 2012, 01:47:16 am »
What I'm trying to say is that for a beginner hobbyist market this chip does not make much sense. LM7833 are pretty hard to find. Not sure how many components in breadboard design one would find at 3.3V. Yes, the ADC and comparator and other integrated stuff are not be meant for professional businesses.
For an advanced hobbyist or industrial market this chip is pretty underpowered.
I know about the 1.8V and even 1.2V, but for those parts I have real EE design engineers doing them, putting along real ADCs, adding JTAG and all the other stuff. And then a layer of embedded SW engineers writing firmware for all the stuff. Then a layer of software/system architects writing the framework. Then a final layer of guys writing the actual functionality of the device.
I'm sure that NXP have done their homework and are able to figure out which market they are addressing, but it does not seem to be chipping away at Microchip's share. I do hope that things will change.
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #19 on: November 14, 2012, 02:29:46 am »
There's loads of 3.3v regulators available.
Pretty much everything I breadboard now uses 3.3v supply. I haven't used a 5v supply for anything for years.
Offline Monkeh
« Reply #20 on: November 14, 2012, 02:37:03 am »
Because an LM317 is hard to develop 3.3V from.
Offline FenderBender
    • The Solid State Workshop
« Reply #21 on: November 14, 2012, 03:15:09 am »
Watch out Microchip and Atmel....
Offline TheDirty
« Reply #22 on: November 14, 2012, 03:34:54 am »
On another note, but in the ARM cortex area, I finally switched from my FT2232 based JTAG with SWD adapter to this J-Link clone I got off of e-Bay.
http://www.powermcu.com/product-20.html
With a 20pin JTAG to 1.27 10 pin SWD Olimex adapter:
https://www.olimex.com/Products/ARM/JTAG/ARM-JTAG-20-10/
It's working well in SWD mode and it's quick.
I'm using it with Rowley Crossworks, but OpenOCD supports J-Link.
Mark Higgins
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #23 on: November 14, 2012, 03:37:12 am »
i really need to push hard my attiny and pic10f stock (50 units each) to market, otherwise i will be doomed.
Offline T4P
  • Country: sg
    • T4P
« Reply #24 on: November 14, 2012, 09:04:00 am »
Freescale's kinetis might sound awesome
I remember recalling unsure who said this but IIRC freescale nearly went bust
And yes, 5V is so 70s ... Use LD1117-3.3 next time
