Haha
, it's the same in Japan.
There used to be a domestic (near domestic) PC called NEC PC-98. in the early 90's, PC-98 was also used to run industrial equipment.
After 30 years, when the PC-98 became extinct, it was time to replace the one used in industrial equipment.
But the trouble was, they could not be easily replaced with PC/AT PCs: NEC had its own expansion bus, the C-bus, which of course was dedicated to PC-98.
for this reason, PC-98s are still sold at high prices on Yahoo auction...
Not only the bus, but also the OS is slightly different, and PC/ATs Windows will not run. at that time, there was a custom Windows for PC-98.
today, NEC itself offers a service to replace troubled PC-98s.
The same is true for those industrial boards on ebay. Those motherboards have a PC/104 or ISA bus. Unfortunately, modern buses, PCI and PCIe, cannot use the DRQ signals required for the ISA or PC/104 bus.
The "ISA" alone is a valuable motherboard.
It should be normal to use them while repairing them, especially since industrial equipment has a long operating life and they are all expensive items that cannot be easily replaced.
even if try to do something about it, the original manufacturer may be bankrupt or try to replace it with a new one.
So these old motherboards are valuable.
Also, the 486 should have been manufactured until 2007. I believe that NOS is still plentiful in China.
There are even brand new newly designed 386
laptops for sale on aliexpress.
