You can try that, or you can use higher external bias.
Edit: I should have read your entire post. No, LCD bias is not AC, it is DC.
Thanks for the reply
but it took so long to get any reply at all, and I went ahead.
I found a Microchip document on it, and it appears this resistor divider arrangement is common.
The variable resistor is typically added to the top, and it changes the voltage of every tap.
Only issue is the 3 inputs are limited in the data sheet to the chip’s supply rail.
When I opened the device, the 33K resistor never existed. It was a 0 ohm link, which was already feeding the top of the divider with Vdd.
So I took the risk and applied a much higher voltage, about 5.5V in place of 3.7V, which fixes the display, but runs the microcontroller out of spec.
Any thought on this?
