Author Topic: OpenSTM32 vs STM32Cube IDE - Same code, different results.  (Read 1340 times)
Offline gvz
« on: August 12, 2019, 08:52:53 pm »
Hi !
I am testing a simple free running UART transmission with an STM32 micro-controller, with both Openstm32 and STM32Cube IDE, and I am experiencing different results between these two different Eclipse based IDEs.
The code is this one:
#ifdef HSE_VALUE
#undef HSE_VALUE
#define HSE_VALUE 8000000UL
#endif
#include "stm32f4xx.h"
#include "stm32f4xx_hal_rcc.h"
#include "stm32f4xx_hal_gpio.h"
#include "stm32f4xx_hal_uart.h"
UART_HandleTypeDef huart1;
void Error_Handler()
void SystemClock_Config(void)
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 5;
  RCC_OscInitStruct.PLL.PLLN = 200;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 4;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV4;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
static void MX_USART1_UART_Init(void)
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
static void MX_GPIO_Init(void)
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
int main(void)
HAL_Init();
SystemClock_Config();
MX_USART1_UART_Init();
MX_GPIO_Init();
while(1)
HAL_UART_Transmit(&huart1, "*", 1, 0);
But flashing the device with OpenSTM32 (right click on project location → Target → Program chip), the device doesn't do anything..
The console output is:
22:28:32 **** Programming project ad371_hal_uart_test on chip ****
/usr/local/share/OpenSTM32/plugins/fr.ac6.mcu.externaltools.openocd.linux64_1.23.0.201904120827/tools/openocd/bin/openocd -f stm32.flash.2695625463917824173.cfg -s /home/gvz/projects/AD371/SOFT/stm32/ad371_hal_uart_test -s /usr/local/share/OpenSTM32/plugins/fr.ac6.mcu.debug_2.5.0.201904120827/resources/openocd/st_scripts -c "program Release/ad371_hal_uart_test.elf verify reset " -c shutdown
Open On-Chip Debugger 0.10.0+dev-00021-g524e8c8 (2019-04-12-08:33)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
srst_only separate srst_nogate srst_open_drain connect_assert_srst
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
adapter speed: 8000 kHz
adapter_nsrst_delay: 100
Info : clock speed 8000 kHz
Info : STLINK v2 JTAG v31 API v2 SWIM v7 VID 0x0483 PID 0x3748
Info : using stlink api v2
Info : Target voltage: 1.741579
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
Info : Stlink adapter speed set to 4000 kHz
Info : STM32F407VGTx.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : Listening on port 3333 for gdb connections
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08001138 msp: 0x20020000
configuring PLL
adapter speed: 4000 kHz
** Programming Started **
auto erase enabled
Info : device id = 0x10076413
Info : flash size = 1024kbytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x20000046 msp: 0x20020000
wrote 16384 bytes from file Release/ad371_hal_uart_test.elf in 0.626915s (25.522 KiB/s)
** Programming Finished **
** Verify Started **
xPSR: 0x61000000 pc: 0x2000002e msp: 0x20020000
verified 6004 bytes in 0.101388s (57.830 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked
22:28:33 Build Finished (took 912ms)
STM32Cube IDE only allows Debug option to reflash the chip, but it works... I am not a fan of STM32Cube IDE, because among other things (it has many known issues), it can erase your custom code if you change something from Cube setup and re-genarate code (that's what I experienced).
Do someone have an idea how to solve this issue with OpenSTM32 ?
I think this is due to an openocd script. How can I edit the "Program chip" setup in Eclipse ?
Any hint ?
Thanks.
g.
Offline hansd
Re: OpenSTM32 vs STM32Cube IDE - Same code, different results.
« Reply #1 on: August 12, 2019, 09:38:59 pm »
Hi, you have to setup your debug configurations. Expand Debug icon and select Debug Configurations. Also STM32CubeIDE does not delete your code it is the integrated CubeMX.
Offline gvz
« Reply #2 on: August 13, 2019, 07:40:15 am »
What should I do with Debug configuration ? Isn't it already configured ?
[attachimg=1]
[attachimg=2]
[attachimg=3]
Offline gvz
« Reply #3 on: August 13, 2019, 08:08:23 am »
I reconfirm that if you apply some change to IC setup, the STM32CubeMX erase your custom code and re-generate it as its default (retested now with the main.c).
Offline gvz
« Reply #4 on: August 13, 2019, 08:30:12 am »
OK it works.
I was missing code for alternate function of GPIO and clock for the UART.
 :popcorn:
Offline thm_w
« Reply #5 on: August 13, 2019, 09:39:30 pm »
I'm assuming here it works the same way as CubeMX, you need to insert your custom code between the tags right:
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  put your code here ONLY
    /* USER CODE END WHILE */
There were also options in cubemx to make a back up of the old code before regenerating it, maybe the IDE has similar options.
Offline gvz
« Reply #6 on: August 16, 2019, 10:33:41 pm »
thm_w, you are right.  :-+
