Author Topic: [solved? i hope] spartan3e-500 sparkfun board, uncommon behavior on bootstrap  (Read 4362 times)
Offline legacyTopic starter
hi guys
i have bought this board
here it is the schematic
the onboard RS232-adapter is damaged (the TX is not working)
so i have removed all the jumpers (on the jp9 connector) which connect the maxim chip to fpga pins, and i wired to external RS232 adaptor (3.3V, 5V tolerant, powered by the fpga regulator at 3.3V).
i have put a 6809 SoC on bram (with SYSD9BUG v1.4 inside) and i have connect an uart cable to my PC
the problem is: it seems there is something which resets the SoC with cause uncommon behavior on the hyper terminal, i see this
SYSD9BUG v1.4 FOR S3E
> WHAT?
> WHAT?
> WHAT?
> WHAT?
that means that the SoC has been reseted several times
The same (VHDL) code has been synthesized for Digilent s3e-500-ug320 (instead of s3e-500-pg208 of the sparkfun board), and i see this on bootstrap
I checked the PowerSupply, 5V,1A, and it is low ripple, also the sparkfun has an onboard regulator that should filter residual noises on Vin
What could be wrong ?
should i investigate about the constraints, the hardware, the HDL ?
any suggestion is welcome  :-+
« Last Edit: May 01, 2014, 04:32:03 pm by legacy »
Re: spartan3e-500 sparkfun board, uncommon behavior on bootstrap
« Reply #1 on: April 30, 2014, 08:35:12 am »
any tips ?
Offline scientist
  • User banned.
« Reply #2 on: April 30, 2014, 11:44:09 pm »
get a new board? trying to work around broken circuits can be fun, but it isn't always successful.
« Reply #3 on: April 30, 2014, 11:48:27 pm »
the only broken part is the RS232 chip, the fpga has passed all the tests, including a very large SoC. The only issue i am experimenting is a strange behavior on bootstrap, once bootstrapped it works fine.
any suggestion about that ?
Offline scientist
  • User banned.
« Reply #4 on: April 30, 2014, 11:53:10 pm »
https://www.sparkfun.com/products/589
Just buy one of these and replace the one on your board. It's $1.95.
« Reply #5 on: May 01, 2014, 01:39:04 am »
i am fine with this external adaptor, the issue is not related to that
Offline scientist
  • User banned.
« Reply #6 on: May 01, 2014, 03:01:12 am »
i would not be surprised if your reset issues are caused by having a different offboard chip.
« Reply #7 on: May 01, 2014, 04:19:12 pm »
it seems that today is the fix day
i have put my hot air station back in order to replace the RS232 damaged chip with a brand new one, all is well all ends well and the rx and tx are now working!
unfortunately i got the same issue about the strange behaviour at bootstrap, so i have put a an eye on the project constraints
i have replaced this
# Time specifications for 50MHz clock (soldered)
# (40%/60% duty-cycle)
NET "CLK_50MHZ"   LOC = "P181"
with this
NET "CLK_50MHZ"   LOC = "P181" | IOSTANDARD = LVCMOS33 ;
NET "CLK_50MHZ" PERIOD = 20 ns HIGH 40 %;
i have also replaced the SYSD9BUG v1.4 firmware with a tiny and extremely easy piece of code that
- waits 200 cycles as early bootstrap
- resets the uart before any initialization
- does extremely paranoid built-in tests (such as address in address, cpu alu test, etc)
- reports everything with TEST(X):{PASSED, FAILED}
and ... i can't understand exactly why and where SYSD9BUG v1.4 has the uncommon behavior bootstrap issue, but according to these paranoid tests i can say the SoC is working on this fpga board because i have no TEST FAILED in my report screen.
my conclusion
(that my be wrong, inaccurate, etc, you have to consider i am not a fpga guru, i am just a fan)
- SYSD9BUG v1.4 has no issues on Digilent s3e-500-fg320 @50Mhz (soldered clock) board, with speedgrade -4 and poor constraints about clock
- SYSD9BUG v1.4 has issues on Sparkfun s3e-500-pq208 @50Mhz (soldered clock) board, speedgrade -4 and poor constraints about clock
- it seems that the Sparkfun s3e-500-pq208 board needs stronger constraints about clock
« Reply #8 on: May 01, 2014, 04:24:13 pm »
in my tests i am resetting the board several and several time, still no uncommon behavioral at the bootstrap
good  ^-^
next point is to understand why Noice09 is not working on both the boards, it should be fine with digilent s3e-500 but it is not working at all  :rant:
i think i will write the fw by myself, it should be not so complicate to add a sort of srec-to-memory, but, to be honest, i like the Noice09 PC side, it's a good piece of software which enables you to download and track an application.
ok  :blah:
thank you for the support  :-+
Offline scientist
  • User banned.
