Author Topic: PCB engraved, what do you think about ?  (Read 30786 times)
Offline legacyTopic starter
Re: PCB engraved, what do you think about ?
« Reply #50 on: November 15, 2014, 09:02:57 pm »
any news, guys ?
« Reply #51 on: November 16, 2014, 12:24:45 am »
i have bought & modified this Proxxon CNC machine, it's cheap and good for my purposes
i do not have money, but i love these machines, which are a lot of light years ahead  :-DD
Offline atferrari
  • Country: ar
« Reply #52 on: November 16, 2014, 01:29:36 am »
Look for Stepcraft (at Iserlohn Germany).
They only lack an automatic tool changer.
There is even a kit to assemble yours as well.
Agustín Tomás
In theory, there is no difference between theory and practice. In practice, however, there is.
« Reply #53 on: November 16, 2014, 02:17:11 am »
is it this one ?
that's cool  :D
Offline atferrari
  • Country: ar
« Reply #54 on: November 16, 2014, 02:52:16 am »
is it this one ?
that's cool  :D
Yes. Three options (sizes).
Peter Urban is a helpful person.
Agustín Tomás
« Reply #55 on: November 16, 2014, 06:12:45 am »
any direct experience about this machine ?
also, which king of PCB Engraving Router-Tools do you suggest ?
just to give an example, something like these ?
(feel free to suggest a better place and tool to buy)
Offline atferrari
  • Country: ar
« Reply #56 on: November 16, 2014, 11:05:18 am »
If you ask to me, my sole experience is that for one day I failed to reach his place and buy it.  >:(  >:(  >:(
He was involved in providing a kit, for quite long time, to modify a Proxxon 70 which included tool changer. (Google Usovo.de)
What always worried me about all this is the uncertain necessity of maintaining / adhering to parallel ports and the like.
Peter seems to have all that solved as well. Even software.
Agustín Tomás
« Reply #57 on: November 17, 2014, 04:19:09 pm »
who has Proxxon MF70 + kit, and used it as PCB engraved ?
Offline Fred27
    • Fred's blog
« Reply #58 on: November 17, 2014, 04:27:03 pm »
That's my Instructable. I'm glad you found it useful.  :)
I've used that little Proxxon for PCB milling (and loads of other stuff) but now moved over to UV exposure. I found that the deeper contours of milled PCBs made dry film solder mask application more difficult.
I'm tempted to move to a larger machine as the main downside to the MF70 is that it's tiny. It's surprisingly capable but has a very small work area, even after some extending it a bit.
« Reply #59 on: November 18, 2014, 10:25:55 pm »
what do you think, guys, about ?
« Reply #60 on: November 19, 2014, 07:53:28 am »
do you think is really possible to do TQFP  with a CNC ?
which are the problems with an engraver ?
Online PlainName
  • Country: va
« Reply #61 on: November 19, 2014, 12:45:41 pm »
Yes, I've done LLGA28L, which is 0.6mm pitch.
The issue with small stuff is not the width of the copper but the width of the gaps. The limit there is a combination of factors: the depth of the tool, angle of the tip, width of the tip, and runout. But these factors are, in turn, affected by other factors: the depth of the cut, for instance, is affected by squareness of the mill bed and flatness of the PCB.
So whilst it is possible to do fine footprints, you can't expect to whip a new mill out of the box and run off that kind of job within half an hour. It can take quite a while to 'bed in' not just the mill and tool, but yourself, and you'll go through a phase where nothing happens as it should and you wonder why you are bothering with this rubbish. But ultimately you should end up with a good idea of the practical limits for your setup and, the important part, being able to consistently run off jobs within that limit.
Note that all these videos show how this stuff works for the people making the videos, but your solution could well be different. For instance, just the matter of holding the PCB down has many solutions, and the one that works every time for me is carpet tape. However, the videos you post show a different method which plainly works for them. There is no right or wrong way, just what works for you, and it is the finding out what works for you that takes some time.
« Reply #62 on: November 19, 2014, 02:15:44 pm »
understood, thank you  :-+
which CNC& tools did you use for LLGA28L ?
Online PlainName
  • Country: va
« Reply #63 on: November 19, 2014, 02:52:24 pm »
I picked up a set of LPKF mills cheaply on Ebay. They are like normal mills (except very small and stubby), 60 degree and 4mil to 8mil, and I run 'em at a depth of 0.09mm.
Due to runout the gap is actually wider than it should be, but it leaves enough copper for the pads to work and, since these would be prototypes, that's good enough for my purposes.
However, I know someone who apparently uses the single edge pointed type of engraving cutter to achieve the same sort of thing. I have no idea how because that just doesn't work for me, but I've seen his impressive results. One thing we have in common is that we spread 3-in-1 across the PCB as a lubricant when doing the isolation milling. Before I did that my results were very variable and tools lasted hardly any time.
