Author Topic: 18F4580 is it compatible with 18F458?  (Read 458 times)
Offline Chriss
« on: October 16, 2019, 08:34:37 pm »
Hi!
I have to change a bad PIC 18F458 but the fastest delivery time I can get a PIC 18F4580.
I have to program a firmware what I actually have wich is for the old PIC 18F458.
I checked in datasheet and compared these two PIC and I can see they should be compatible,
but I have only the compiled hex file what I have to program into the new PIC.
Could this work if I interchange the old burned PIC 18F458 with the new type PIC 18F4580 and upload the firmware what I have
from the 18F458?
Does somebody have any experience with this kind of mixing?
Thank you very much.
My best regards.
Offline 1Ghz
  • Country: kr
Re: 18F4580 is it compatible with 18F458?
« Reply #1 on: October 16, 2019, 08:46:58 pm »
PIC18F458 to PIC18F4580 Migration Document http://ww1.microchip.com/downloads/en/DeviceDoc/39661a.pdf
The following users thanked this post: Chriss
Online Ian.M
« Reply #2 on: October 16, 2019, 09:16:31 pm »
TLDR:
Pin compatible - Yes
Binary code compatible - No, for anything much more complex than 'blink a LED', even if you patch the CONFIG, due to the many SFR and hardware peripheral module differences.
OTOH if you've got full sourcecode + the corrct compiler to rebuild it, you are in with a chance of porting it sucessfully if you carefully work through the code, referring to the migration document 1GHz linked, and the two device datasheets, and all the PIC 18F4580 errata, adapting the code as required.
« Last Edit: October 16, 2019, 09:23:05 pm by Ian.M »
Offline jackthomson41
« Reply #3 on: October 19, 2019, 02:11:12 pm »
It would be wise to use PIC18F458 but if you have to replace it then you need to change the configuration bits of your code i.e. change microcontroller name in your compiler and upload the hex file in your new microcontroller PIC 18F4580.
But if you just have the hex file and not the code then it's impossible to replace.
Offline Chriss
« Reply #4 on: October 19, 2019, 07:17:17 pm »
Thank you guys, you helped me really to make a decision.
Thanks.
My best regards.
